Thermostat tse, 270mm, 099043
Reference ADEPEM : 045737
Reference ADEPEM : 002087
Reference ADEPEM : 007301
Reference ADEPEM : 010829
Resistance 1200w 282019cnb
Type: ResistancesFagor, Brandt, Edesa
Reference ADEPEM : 070357
Anode 250mm pas de 8, 040164
Reference ADEPEM : 025740
Reference ADEPEM : 025742
Resistance 800w 95x0068
Reference ADEPEM : 072669
Joint embase 220088002
Type: JointsFagor, Brandt, Edesa
Reference ADEPEM : 034401
Reference ADEPEM : 025184
Reference ADEPEM : 117139
Thermostat tus 450mm à cosses
Type: ThermostatsFagor, Edesa
Reference ADEPEM : 122629
Thermostat gtlh0200 / nt-1a2 283310cav
Type: ThermostatsFagor, Brandt
Reference ADEPEM : 063143
Resistance 900w l=428
Type: ResistancesFagor, California, Edesa
Reference ADEPEM : 087085
Corps de chauffe 2400w as0019133 origine
Type: Corps de chauffeFagor, Ocean
Reference ADEPEM : 087120
Thermostat 450mm tse0001407
Reference ADEPEM : 058763
Thermostat bbsc0055
Type: ThermostatsFagor, Brandt, Ocean
Reference ADEPEM : 064680
Joint d'embase 6 trous as0020603
Type: JointsFagor, Hoover, Sanyo
Reference ADEPEM : 122346
Reference ADEPEM : 161831
Resistance 1000w
Type: ResistancesFagor, Edesa
Reference ADEPEM : 103771
Reference ADEPEM : 055120
Resistance 600w 282019ccr
Reference ADEPEM : 128995
Douille 20/27
Type: DiversFagor, Brandt
Reference ADEPEM : 114422
Resistance 1500w
Reference ADEPEM : 071932
Couvercle boitier
Type: Capots et couverclesFagor
Reference ADEPEM : 117350
Soupape de securite 3/4 10 bar
Type: Soupapes et clapetsFagor, Edesa, Aspes
Reference ADEPEM : 114367
Thermostat
Reference ADEPEM : 166968
Thermostat (tri) bts50005
Reference ADEPEM : 145631
Bride
Type: DiversFagor
Reference ADEPEM : 127085
Embase 5 trous resistance 1200w
Reference ADEPEM : 129003
Embase resistance 3x800w 6 trous
Reference ADEPEM : 103900
Microswitch+fils
Type: Interrupteurs et switchRowenta, Fagor, Singer portg-arcasa
Reference ADEPEM : 035551
Module electronique t31c001m0
Type: ModulesFagor, Brandt
Reference ADEPEM : 129005
Resistance steatite 1800w d=51
Reference ADEPEM : 147786
Sonde de temperature
Type: Capteurs et sondesFagor, Brandt
Reference ADEPEM : 149038
Thermostat 80°nc rearmable de securite
Reference ADEPEM : 094179
Corps de chauffe as0019133 adaptable
Reference ADEPEM : 208169
Anode 240mm d=25,5 pas de 8 291126
Type: AnodesFagor, Thermaglas, Regent
Reference ADEPEM : 113482
Sacs aspirateur par 5
Type: SacsHoover, Fagor, Singer portg-arcasa
Reference ADEPEM : 028613
Sacs aspirateur par 4
Type: SacsSamsung, Tornado, Bomann
Reference ADEPEM : 045617
Bouton thermostat t34b002l0
Type: BoutonsFagor
Reference ADEPEM : 133256
Joint de resistance
Type: JointsFagor
Reference ADEPEM : 114421
Thermostat de securite
Reference ADEPEM : 170310
