Filtre a charbon rond type 210
Type: FiltresBosch, Siemens, Brandt
Reference ADEPEM : 030502
Reference ADEPEM : 018667
Reference ADEPEM : 019436
Reference ADEPEM : 079923
Reference ADEPEM : 029941
Durite electrovanne 1m, d=10
Reference ADEPEM : 030286
Reference ADEPEM : 033771
Reference ADEPEM : 019462
Poulie tambour 52x6225
Reference ADEPEM : 041772
Reference ADEPEM : 049620
Amortisseur wtg209600
Reference ADEPEM : 044635
Reference ADEPEM : 099169
Condensateur 18µf 450v 50246552009
Reference ADEPEM : 029942
Securite verrouillage 55x3548
Reference ADEPEM : 033591
Boite a produits wtg814800
Reference ADEPEM : 019430
Manchette de cuve 55x2962
Reference ADEPEM : 036098
Reference ADEPEM : 098824
Axe de porte
Reference ADEPEM : 051493
Reference ADEPEM : 018560
Thermoplongeur 2000w 55x7327
Reference ADEPEM : 040469
Courroie 1233j5 = 5pj1233
Reference ADEPEM : 019144
Tuyau de vidange wtg341300
Type: Tuyaux et duritesBrandt, Vedette, Bosch
Reference ADEPEM : 040919
Pompe de vidange askoll m116
Reference ADEPEM : 049852
Bride thermoplongeur
Reference ADEPEM : 037201
Collier de fixation moteur wt23385f0
Type: Colliers et clipsBrandt, Vedette, Fagor
Reference ADEPEM : 101353
Distributeur+cable
Reference ADEPEM : 040482
Ensemble de blocage de tuyau
Type: DiversBrandt, Vedette, Fagor
Reference ADEPEM : 101365
Support module puissance
Type: ModulesVedette, Brandt, Thomson
Reference ADEPEM : 070632
Pied
Type: PiedsBrandt, Vedette, Thomson
Reference ADEPEM : 059642
Resistance 1950w 124032547/0
Reference ADEPEM : 005053
Ressort fixation distributeur wt3227200
Reference ADEPEM : 080732
Reference ADEPEM : 039580
Vis de poulie + ecrou
Type: Visserie et emboutsBrandt, Vedette, Bosch
Reference ADEPEM : 085075
Patin amortisseur
Type: PiedsBrandt, Vedette, Bosch
Reference ADEPEM : 019435
Poulie tambour
Type: Pignons et pouliesBrandt, Vedette, Thomson
Reference ADEPEM : 019056
Roulette arriere
Type: Roues et roulettesBrandt, Vedette, Bosch
Reference ADEPEM : 035654
Bride de fixation
Reference ADEPEM : 069442
Couvercle additifs
Type: Capots et couverclesBrandt, Vedette, Bosch
Reference ADEPEM : 074998
Filtre ll fond de cuve
Type: FiltresBrandt, Vedette, Thomson
Reference ADEPEM : 041422
Guide de bouton
Type: BoutonsBrandt, Thomson, Vedette
Reference ADEPEM : 019429
Support patin amortisseur
Reference ADEPEM : 052770
Type: ResistancesBrandt, Vedette, Nogamatic
Reference ADEPEM : 018714
Bornier
Type: ConnectiquesBrandt, Vedette, Fagor
Reference ADEPEM : 018483
Bouche trou
Reference ADEPEM : 047549
Cache manchette
Type: DiversVedette, Thomson, Fagor
Reference ADEPEM : 060336
Came de distribution
Type: DiversVedette, Brandt, Sauter
Reference ADEPEM : 013788
Courroie 1126j4
Type: CourroiesThomson, Arthur martin, Frigeavia
Reference ADEPEM : 004905
Cuve partie inferieure
Type: Cuves et tamboursBrandt, Vedette, Bosch
Reference ADEPEM : 060800
Cuve partie superieure lestee 20kg
Reference ADEPEM : 067407
Durite cuve/boite
Type: Tuyaux et duritesBrandt, Vedette, Thomson
Reference ADEPEM : 018561
Durite pressostat
Reference ADEPEM : 060230
Reference ADEPEM : 018552
Levier de came
Type: Crochets et leviersBrandt, Vedette, Thomson
Reference ADEPEM : 110558
Manchons de poulie par 2
Type: DiversVedette, Brandt, Thomson
Reference ADEPEM : 039657
Plinthe+portillon
Reference ADEPEM : 019433
Potentiometre 1m ohms
Type: Commutateurs et selecteursVedette, Brandt, Thomson
Reference ADEPEM : 041707
Profil fixation panneau lateral
Reference ADEPEM : 040800
Programmateur td010017
Type: Minuteurs et programmateursVedette, Brandt, Sauter
Reference ADEPEM : 038426
Ressort de cuve arriere
Reference ADEPEM : 033763
Securite verrou
Type: Securites et verrousBrandt, Vedette, Thomson
Reference ADEPEM : 018738
Support tuyau
Type: Supports et fixationsBrandt, Vedette, Fagor
Reference ADEPEM : 101359
Thermoplongeur 2200w
Type: ResistancesThomson, Frigeavia, Frigidaire
Reference ADEPEM : 030767
Thermostat reglable
Type: ThermostatsBrandt, Thomson, Vedette
Reference ADEPEM : 035656
Vis de patin amortisseur
Type: Visserie et emboutsBrandt, Vedette, Fagor
Reference ADEPEM : 101363
Bloc roulette avant
Reference ADEPEM : 092599
Roulette avant 00168701
Type: Roues et roulettesBrandt, Bosch, Vedette
Reference ADEPEM : 079465
Electrovanne 2 voies 55x8396, 4055066387
Type: ElectrovannesThomson, A.e.g, Ariston
Reference ADEPEM : 030802
Reference ADEPEM : 019362
Pompe de vidange 290889
Reference ADEPEM : 034623
Pompe de vidange 74803
Reference ADEPEM : 078883
Chapeau bruleur d=80 semi-rapide
Reference ADEPEM : 037674
Durite cuve/pompe
Reference ADEPEM : 038527
Bloc secteur
Reference ADEPEM : 048988
