Reference ADEPEM : 035761
Reference ADEPEM : 111588
Reference ADEPEM : 018667
Courroie 1225j5 = 5epj1225, 41021973
Type: CourroiesCandy, Hoover, Zerowatt
Reference ADEPEM : 092980
Reference ADEPEM : 055848
Reference ADEPEM : 062873
Sécurité de porte 49030389
Type: Securites et verrousCandy, Hoover, Rosieres
Reference ADEPEM : 055358
Reference ADEPEM : 063907
Bouchon de vidange 41021233
Type: BouchonsCandy, Hoover, Zerowatt
Reference ADEPEM : 097999
Aube de tambour 41021913, as0040544
Type: Aubes de tambourCandy, Hoover, Zerowatt
Reference ADEPEM : 082541
Reference ADEPEM : 078394
Charniere de hublot l79a001a2, 52x2171
Reference ADEPEM : 033748
Pompe de vidange l71b014i1
Reference ADEPEM : 052008
Sonde ctn 49015420
Type: Capteurs et sondesCandy, Hoover, Zerowatt
Reference ADEPEM : 092862
Ressort de cuve, l=178, 41031863
Type: Amortisseurs et ressortsCandy, Hoover, Zerowatt
Reference ADEPEM : 133938
Reference ADEPEM : 099169
Poulie tambour d=278 41024467
Type: Pignons et pouliesCandy, Hoover, Zerowatt
Reference ADEPEM : 102698
Joint spi 32x52x10 l57a001a4
Reference ADEPEM : 071005
Pompe de vidange 9010341, 41019104
Type: PompesCandy, Hoover, Zerowatt
Reference ADEPEM : 119645
Reference ADEPEM : 039081
Courroie 1184j5
Reference ADEPEM : 008426
Reference ADEPEM : 048025
Bouchon de pompe
Type: BouchonsBrandt, Fagor, Vedette
Reference ADEPEM : 098420
Courroie 1184j6 132353130/9
Type: CourroiesElectrolux, Fagor, A.e.g
Reference ADEPEM : 070934
Boitier module
Type: ModulesCandy, Baumatic
Reference ADEPEM : 154475
Goupille amortisseur 41017173
Reference ADEPEM : 120558
Hublot verre l49a002b8
Reference ADEPEM : 040981
Pressostat 41035075
Type: PressostatsCandy, Hoover, Zerowatt
Reference ADEPEM : 116094
Filtre antiparasite 0,47µf as0031772
Type: CondensateursBrandt, Fagor, Vedette
Reference ADEPEM : 101403
Module clavier 41041468
Type: ModulesCandy, Rosieres, Baumatic
Reference ADEPEM : 150118
Charniere de hublot
Type: CharnieresFagor, Brandt, Vedette
Reference ADEPEM : 065426
Carter ventilateur inferieur
Type: Boitiers et cartersCandy, Hoover, Rosieres
Reference ADEPEM : 125461
Durite cuve/pompe as0031774
Reference ADEPEM : 067065
Collier avant fixation soufflet 41018408
Type: Colliers et clipsCandy, Hoover, Zerowatt
Reference ADEPEM : 120368
Cerclage hublot interieur
Reference ADEPEM : 054182
Hublot verre seul
Type: HublotsCandy, Hoover, Zerowatt
Reference ADEPEM : 083151
Resistance de sechage 1300w 41027546
Type: ResistancesCandy, Hoover, Rosieres
Reference ADEPEM : 144500
Vis de fixation poulie
Type: Visserie et emboutsCandy, Hoover, Zerowatt
Reference ADEPEM : 146387
Sonde sechage, 41032956
Reference ADEPEM : 073643
Carter superieur sechage
Reference ADEPEM : 111997
Type: Tuyaux et duritesCandy, Hoover, Zerowatt
Reference ADEPEM : 102291
Type: PressostatsBrandt, Fagor, Vedette
Reference ADEPEM : 088133
Soufflet de hublot l21b010c6
Type: JointsBrandt, Fagor, De dietrich
Reference ADEPEM : 068163
Charniere de hublot
Type: CharnieresCandy, Hoover, Zerowatt
Reference ADEPEM : 131589
Collier de soufflet avant
Type: Colliers et clipsFagor, Brandt, Vedette
Reference ADEPEM : 076456
Contre poids superieur
Type: DiversCandy, Hoover, Rosieres
Reference ADEPEM : 145039
Enjoliveur top droit
Type: Capots et couverclesCandy, Hoover, Zerowatt
Reference ADEPEM : 096205
Joint sonde temperature
Reference ADEPEM : 108745
Thermostat de securite 180° 41034167
Type: ThermostatsCandy, Hoover, Rosieres
Reference ADEPEM : 132830
Tiroir lessive + boitier L48A019A5
Type: Distributeurs lessiveFagor, Brandt, Vedette
Reference ADEPEM : 054332
Turbine plastique
Type: Ventilateurs et helicesCandy, Hoover, Rosieres
Reference ADEPEM : 135330
Contrepoids inferieur
Type: DiversCandy, Hoover, Zerowatt
Reference ADEPEM : 103242
Securite hublot zv445 l39a000i6
Reference ADEPEM : 034677
Thermostat 96°nc / 24°
Type: ThermostatsFagor, Brandt, Vedette
Reference ADEPEM : 048066
