Reference ADEPEM : 171573
Condensateur 7µf c00279233
Reference ADEPEM : 114797
Reference ADEPEM : 005886
Reference ADEPEM : 018667
Courroie 1225j5 = 5epj1225, 41021973
Type: CourroiesCandy, Hoover, Zerowatt
Reference ADEPEM : 092980
Roulement 6000z, 10x26x8mm
Reference ADEPEM : 008806
Courroie 1930h7 8996470700601
Type: CourroiesBosch, Siemens, Candy
Reference ADEPEM : 052743
Sécurité de porte 49030389
Type: Securites et verrousCandy, Hoover, Rosieres
Reference ADEPEM : 055358
Resistance, 2100w, 41042963
Type: ResistancesCandy, Hoover, Zerowatt
Reference ADEPEM : 145705
Aube de tambour 43005989
Type: Aubes de tambourCandy, Hoover
Reference ADEPEM : 192842
Amortisseur 120n 49043541, 41017170
Type: Amortisseurs et ressortsCandy, Brandt, Hoover
Reference ADEPEM : 107611
Reference ADEPEM : 048944
Courroie 1194j5 = 5pj1194
Type: CourroiesIndesit, Ariston, Hotpoint
Reference ADEPEM : 008699
Bouchon de vidange 41021233
Type: BouchonsCandy, Hoover, Zerowatt
Reference ADEPEM : 097999
Aube de tambour 41021913, as0040544
Type: Aubes de tambourCandy, Hoover, Zerowatt
Reference ADEPEM : 082541
Manchette 55x3754, 00475583
Reference ADEPEM : 033762
Amortisseur 120n 41017168
Type: Amortisseurs et ressortsCandy, Hoover, Brandt
Reference ADEPEM : 190883
Roulement 6203zz, 17x40x12mm
Reference ADEPEM : 030301
Roulement 6202z, 15x35x11mm
Reference ADEPEM : 030302
Reference ADEPEM : 029941
Soufflet de hublot 43019185
Type: JointsCandy, Hoover, Zerowatt
Reference ADEPEM : 088470
Roulement etanche 6205-2rs, 25x52x15mm
Type: Roulements et paliersHonda, Candy, Al-ko
Reference ADEPEM : 116975
Reservoir a eau 40009648, 40008542
Type: ReservoirsCandy, Hoover, Otsein
Reference ADEPEM : 107050
Durite electrovanne 1m, d=10
Reference ADEPEM : 030286
Poignee de porte 43011740
Type: PoigneesCandy, Hoover
Reference ADEPEM : 173992
Sacs aspirateur par 5 + filtre
Type: SacsElectrolux, Progress, Philips
Reference ADEPEM : 043324
Pompe de vidange b20-6b, 46003742
Type: PompesCandy, Hoover, Iberna
Reference ADEPEM : 095748
Courroie 1200h8, 46000003, 46007433
Type: CourroiesCandy, Iberna, Proline
Reference ADEPEM : 059413
Roulement 6202luv 15x39x13mm 40004307
Type: Roulements et paliersCandy, Hoover, Zerowatt
Reference ADEPEM : 116534
Sonde ctn 49015420
Type: Capteurs et sondesCandy, Hoover, Zerowatt
Reference ADEPEM : 092862
Condensateur 12,5µf 400v
Reference ADEPEM : 029938
Roulement etanche 6206rs, 30x62x16mm
Type: Roulements et paliersCandy, Hoover, Gorenje
Reference ADEPEM : 116976
Sacs aspirateur par 4 sb242-nw
Type: SacsElectrolux, Philips, Tornado
Reference ADEPEM : 028762
Charniere habillage 92784297
Type: CharnieresCandy, Rosieres, Hoover
Reference ADEPEM : 026278
Ressort de cuve, l=178, 41031863
Type: Amortisseurs et ressortsCandy, Hoover, Zerowatt
Reference ADEPEM : 133938
Roulement 6201z 12x32x10mm
Reference ADEPEM : 030297
Chapeau bruleur d=90
Type: BruleursBrandt, Bompani, Fagor
Reference ADEPEM : 023877
Palier tambour moyeu, 46005903
Type: Roulements et paliersCandy, Hoover, Iberna
Reference ADEPEM : 063444
Pompe de vidange 72886, 41018403
Type: PompesCandy, Hoover, Zerowatt
Reference ADEPEM : 092603
Cadre superieur, 43013198
Type: DiversCandy
Reference ADEPEM : 192694
Charbons par 2 , 49028931 , 5x12,5x30
Type: Charbons moteurCandy, Ariston, Hoover
Reference ADEPEM : 046887
Couvercle complet 43007446
Type: Capots et couverclesCandy, Thomson
Reference ADEPEM : 180338
Condensateur 7,5µf 420v-450v c00095649
Type: CondensateursCandy, Rosieres, Bellavita
Reference ADEPEM : 073041
Courroie 1210j5, 1290775400
Reference ADEPEM : 037408
Antiparasites 0,1µf 2x0,027µf
Reference ADEPEM : 058839
Poulie tambour d=278 41024467
Type: Pignons et pouliesCandy, Hoover, Zerowatt
Reference ADEPEM : 102698
Reference ADEPEM : 005890
Securite de porte da053 /da004, 46002826
Type: Securites et verrousCandy, Hoover, Iberna
Reference ADEPEM : 046494
Antiparasite 91200098
Reference ADEPEM : 100889
Pompe de vidange 9010341, 41019104
Reference ADEPEM : 119645
Thermoplongeur 1300w + sonde 41042459
Reference ADEPEM : 160298
Electrovanne 2 voies, 41032538
Type: ElectrovannesCandy, Hoover, Iberna
Reference ADEPEM : 080387
Amortisseur 100n 70010336
Type: Amortisseurs et ressortsCandy, Hoover, Iberna
Reference ADEPEM : 168111
Charniere de hublot 49001262
Type: CharnieresCandy, Hoover, Iberna
Reference ADEPEM : 048996
Sacs aspirateur par 4 microfibre
Type: SacsTornado, Progress, Privileg
Reference ADEPEM : 034222
Bouchon de pompe 41004157
Reference ADEPEM : 073740
Commutateur 42.09001.018
Type: Commutateurs et selecteursCandy, Rosieres, Hoover
Reference ADEPEM : 104066
Boitier module
Type: ModulesCandy, Baumatic
Reference ADEPEM : 154475
Charbon par 1 , c00296122 , 5x13,5x26
Type: Charbons moteurWhirlpool, Bauknecht, Laden
Reference ADEPEM : 096648
Durite pressostat 5m
Reference ADEPEM : 030280
Reference ADEPEM : 030827
Goupille amortisseur 41017173
Reference ADEPEM : 120558
Pressostat 41035075
Type: PressostatsCandy, Hoover, Zerowatt
Reference ADEPEM : 116094
Soufflet de hublot, 43020484, 43026507
Reference ADEPEM : 083232
Thermoplongeur, 2200w + sonde, 41029722
Type: ResistancesHoover, Candy, Zerowatt
Reference ADEPEM : 109671
Plan superieur
Type: DiversCandy, Iberna
Reference ADEPEM : 130763
Type: SacsTornado, Electrolux, Volta
Reference ADEPEM : 101129
Reference ADEPEM : 029939
Courroie 1233j5 = 5pj1233
Reference ADEPEM : 019144
Courroie 3l454
Reference ADEPEM : 025809
Interrupteur marche / arret 90489683
Type: Interrupteurs et switchCandy, Rosieres, Hoover
Reference ADEPEM : 078158
Palier cote poulie 51x2164
Type: Roulements et paliersBrandt, Vedette, De dietrich
Reference ADEPEM : 030848
Reference ADEPEM : 017904
Bouchon de pompe 91940540
Type: BouchonsCandy, Rosieres, Zerowatt
Reference ADEPEM : 026341
Feutre avant
Type: DiversCandy, Hoover, Zerowatt
Reference ADEPEM : 086179
Joint spi 25x47x8,7
Type: JointsCandy, Rosieres
Reference ADEPEM : 025975
Module clavier 41041468
Type: ModulesCandy, Rosieres, Baumatic
Reference ADEPEM : 150118
Module de commande 41041465
Type: ModulesCandy, Hoover, Iberna
Reference ADEPEM : 162544
Palier oppose poulie 51x2165
Type: Roulements et paliersVedette, Brandt, De dietrich
Reference ADEPEM : 030847
Pompe de vidange, 49002228, 41005959
Reference ADEPEM : 056037
Pressostat 41042893
Reference ADEPEM : 213913
Securite t12 481927138287
Reference ADEPEM : 030920
Voyant orange 93431195
Type: Lampes et ampoulesRosieres, Candy
Reference ADEPEM : 026828
Couvercle boite a produit
Type: Capots et couverclesCandy, Hoover, A.e.g
Reference ADEPEM : 093124
Crochet de hublot
Type: HublotsCandy
Reference ADEPEM : 159186
Durite condenseur
Type: Tuyaux et duritesCandy, Hoover, Rosieres
Reference ADEPEM : 098656
Type: ModulesCandy
Reference ADEPEM : 165320
Support amortisseur
Type: Supports et fixationsCandy, Hoover, Rosieres
Reference ADEPEM : 185507
Thermoplongeur 1950w + sonde 41028717
Type: ResistancesCandy, Hoover, Rosieres
Reference ADEPEM : 025772
Durite cuve/pompe 41001597
Type: Tuyaux et duritesCandy, Hoover, Zerowatt
Reference ADEPEM : 025815
Frein de porte
Reference ADEPEM : 053300
Joint de porte 40005393
Reference ADEPEM : 086133
Type: ModulesHoover, Candy, Terzismo
Reference ADEPEM : 152126
Type: ModulesCandy
Reference ADEPEM : 104021
Module de puissance 49023459
Type: ModulesCandy
Reference ADEPEM : 159431
Module de puissance 49027648
Type: ModulesCandy
Reference ADEPEM : 133151
Poulie tambour, 46004459
Type: Pignons et pouliesCandy, Hoover, Selecline
Reference ADEPEM : 169597
Sonde ctn 49005297
Reference ADEPEM : 062913
Charniere de hublot
Type: CharnieresIberna, Candy
Reference ADEPEM : 068029
