Palier gauche 4071430963
Reference ADEPEM : 076170
Kit palier droit + gauche
Reference ADEPEM : 210285
Palier droit 4071430971
Reference ADEPEM : 076172
Courroie 5pje1196, 1323531200
Reference ADEPEM : 005049
Reference ADEPEM : 005886
Courroie 1199j5, 1462477009
Reference ADEPEM : 044006
Reference ADEPEM : 149883
Reference ADEPEM : 076419
Joint bas de porte 1527401002
Reference ADEPEM : 041333
Amortisseur (x1) 60n 1322553510
Reference ADEPEM : 040625
Pressostat analogique, 3792216040
Reference ADEPEM : 088228
Roulement 6203zz, 17x40x12mm
Reference ADEPEM : 030301
Bobine + fil 1,5mm a6053
Type: Bobines et filsBlack & decker, Curtiss, Hoover
Reference ADEPEM : 084400
Palier gauche d=20mm 4071306494
Type: Roulements et paliersArthur martin, A.e.g, Faure
Reference ADEPEM : 036546
Palier droit d=20mm 4071306502
Reference ADEPEM : 037280
Joint de cuve (manchette) 4071425344
Type: JointsElectrolux, Faure, A.e.g
Reference ADEPEM : 086696
Courroie 1270j5 c00027206
Reference ADEPEM : 018184
Courroie 1287h8 = 8phe1287 1326721006
Reference ADEPEM : 030004
Couvercle de bobine a6057/a6062
Type: Capots et couverclesBlack & decker, Curtiss, Hoover
Reference ADEPEM : 123823
Aube de tambour 53188954431
Type: Aubes de tambourElectrolux, Faure, Arthur martin
Reference ADEPEM : 034005
Pompe de vidange bpx2-14l
Reference ADEPEM : 187912
Thermoplongeur, 1950w , 1325064234
Type: ResistancesElectrolux, Faure, A.e.g
Reference ADEPEM : 084066
Joint de filtre 126061601/4
Reference ADEPEM : 065217
Courroie 1280j6 = 1282j6
Type: CourroiesArthur martin, Faure, Zanussi
Reference ADEPEM : 017801
Courroie el1200j6 c00269093
Type: CourroiesArthur martin, A.e.g, Electrolux
Reference ADEPEM : 005048
Securite de porte zv446l dc64-00653a
Type: Securites et verrousSamsung, Faure, Curtiss
Reference ADEPEM : 077175
Securite de porte, zv-446l10, as0033141
Type: Securites et verrousVedette, Proline, Continental edison
Reference ADEPEM : 172410
Joint spi 47x80x11/12,5 379002420/6
Type: JointsElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 068694
Collier avant soufflet
Type: Colliers et clipsElectrolux, Zanussi, Faure
Reference ADEPEM : 050351
Courroie 10x460 z18
Type: CourroiesCurtiss, Sandri garden
Reference ADEPEM : 187737
Courroie 1200j4 1323531002
Type: CourroiesA.e.g, Electrolux, Zanussi
Reference ADEPEM : 004904
Ecrou du repartiteur
Reference ADEPEM : 120155
Filtre d'aube
Type: FiltresFaure, Electrolux, Arthur martin
Reference ADEPEM : 079488
Ressort avant de cuve l=155 146863302/7
Type: Amortisseurs et ressortsElectrolux, Faure, A.e.g
Reference ADEPEM : 107182
Reference ADEPEM : 060855
Type: ElectrovannesFaure, Arthur martin, Zanussi
Reference ADEPEM : 020726
Reference ADEPEM : 120158
Charbon par 1 , c00296122 , 5x13,5x26
Type: Charbons moteurWhirlpool, Bauknecht, Laden
Reference ADEPEM : 096648
Axe amortisseur 1327804017
Reference ADEPEM : 079414
Bouchon de filtre
Type: BouchonsA.e.g, Electrolux, Faure
Reference ADEPEM : 065216
Reference ADEPEM : 038863
Aube tambour lestee l=20cm 146906604/5
Type: Aubes de tambourFaure, Electrolux, Zanussi
Reference ADEPEM : 099846
Durite boite/cuve
Type: Tuyaux et duritesArthur martin, A.e.g, Faure
Reference ADEPEM : 072067
Pressostat 65/45 152818902/8
Reference ADEPEM : 070343
Securite de hublot
Type: Securites et verrousElectrolux, A.e.g, Zanussi
Reference ADEPEM : 017611
Reference ADEPEM : 029939
Poignee hublot blanche
Type: PoigneesFaure, Curtiss, Domeos
Reference ADEPEM : 043456
Ressort de cuve l=165
Type: Amortisseurs et ressortsElectrolux, A.e.g, Faure
Reference ADEPEM : 162911
Collier arriere soufflet 132002400/1
Type: Colliers et clipsElectrolux, A.e.g, Zanussi
Reference ADEPEM : 100382
Type: ElectrovannesElectrolux, Faure, A.e.g
Reference ADEPEM : 141729
Pompe de vidange 1460573205
Type: PompesArthur martin, Faure, Electrolux
Reference ADEPEM : 081809
Roulement 6304z 19x52x14mm
Type: Roulements et paliersBauknecht, Whirlpool, Brandt
Reference ADEPEM : 030314
Type: Tuyaux et duritesFaure, Electrolux, Zanussi
Reference ADEPEM : 074557
Module de commande*
Type: ModulesFaure, Electrolux, Arthur martin
Reference ADEPEM : 153777
Ressort suspension l=175 126883220/9
Type: Amortisseurs et ressortsFaure, Electrolux, Zanussi
Reference ADEPEM : 090165
Antiparasite 0,47µf
Type: CondensateursElectrolux, A.e.g, Faure
Reference ADEPEM : 061142
Durite boite a produit-cuve 1108513001
Type: Tuyaux et duritesA.e.g, Faure, Electrolux
Reference ADEPEM : 074145
Durite vapeur a soufflet
Type: Tuyaux et duritesArthur martin, Electrolux, Zanussi
Reference ADEPEM : 040526
Type: ElectrovannesElectrolux, A.e.g, Zanussi
Reference ADEPEM : 108434
Poulie tambour d=315
Type: Pignons et pouliesFaure, Arthur martin, Zanussi
Reference ADEPEM : 049397
Bague de fixation tuyau
Type: Tuyaux et duritesZanussi, Faure, Arthur martin
Reference ADEPEM : 099482
Bouchon blanc fixation
Type: BouchonsArthur martin, Electrolux, Zanussi
Reference ADEPEM : 090219
Bouton programmateur
Type: BoutonsCurtiss, Faure, Electrolux
Reference ADEPEM : 082520
Cerclage hublot interieur
Type: HublotsFaure, Zanussi, Arthur martin
Reference ADEPEM : 010457
Durite electrovanne - boite a produits
Type: Tuyaux et duritesCurtiss
Reference ADEPEM : 126158
Fixation manchette inferieure
Type: Supports et fixationsFaure, Arthur martin, Zanussi
Reference ADEPEM : 040683
Flasque
Type: DiversArthur martin, Zanussi, Faure
Reference ADEPEM : 036654
Reference ADEPEM : 049750
Joint roulement 21x40x7
Type: JointsWhirlpool, Ignis, Laden
Reference ADEPEM : 015937
Manchette de cuve
Type: JointsFaure, Arthur martin, Zanussi
Reference ADEPEM : 040681
Pied reglable 124046705/8
Type: PiedsElectrolux, Faure, A.e.g
Reference ADEPEM : 005586
Poignee de hublot
Type: PoigneesZanussi, Ikea, Faure
Reference ADEPEM : 168467
Type: PoigneesFaure, Zanussi, Bellavita
Reference ADEPEM : 104609
Poulie tambour d=272
Type: Pignons et pouliesA.e.g, Electrolux, Arthur martin
Reference ADEPEM : 046982
Tiroir a produits
Type: Bacs et paniersCurtiss, Proline
Reference ADEPEM : 194188
Traverse avant
Reference ADEPEM : 091622
Securite de porte da063663
Type: Securites et verrousFaure, Electrolux, Arthur martin
Reference ADEPEM : 185133
Panier a couverts 1525593008
Reference ADEPEM : 074931
Reference ADEPEM : 075295
Joint spi 30x52x10/12 0041747/8
Type: JointsBosch, Arthur martin, Siemens
Reference ADEPEM : 017289
Filtre complet
Type: FiltresWhirlpool, Ignis, New pol
Reference ADEPEM : 003360
Resistance 1950w 124032547/0
Reference ADEPEM : 005053
Couvercle blanc 192525100/9
Type: Capots et couverclesArthur martin, Faure, Electrolux
Reference ADEPEM : 083162
Joint de palier 22x40x8/11,5
Type: JointsArthur martin, Zanussi, Faure
Reference ADEPEM : 034434
Ressort arriere cuve l=175 146641908/0
Reference ADEPEM : 161972
Roulettes de rail par 4, 50299970009
Reference ADEPEM : 182150
Bras de lavage inferieur
Reference ADEPEM : 120160
Grand couvercle de la boite produit
Type: Capots et couverclesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 085254
Hublot complet
Type: HublotsProline, Continental edison, Curtiss
Reference ADEPEM : 167086
Joint spi 35x57x7 124968500/7
Reference ADEPEM : 050333
Joint tuyau alimentation 124015102/5
Type: JointsElectrolux, Arthur martin, Faure
Reference ADEPEM : 059690
Programmateur 0705/2/0
Type: Minuteurs et programmateursArthur martin, Faure, Zanussi
Reference ADEPEM : 042661
Soufflet de hublot 6781908998
Type: JointsSidex, Gorenje, Far
Reference ADEPEM : 030065
Crochet de porte lave linge
Type: Crochets et leviersArthur martin, Faure, Electrolux
Reference ADEPEM : 005579
Pompe de vidange px-2-35 35w
Type: PompesHaier, Proline, Curtiss
Reference ADEPEM : 187937
Poulie tambour d=273
Reference ADEPEM : 127612
Vis de poulie
Type: Visserie et emboutsElectrolux, Faure, A.e.g
Reference ADEPEM : 168967
Durite bac pompe de vidange
Type: Tuyaux et duritesA.e.g, Arthur martin, Zanussi
Reference ADEPEM : 073473
Type: ElectrovannesFaure, Electrolux, Zanussi
Reference ADEPEM : 073260
Type: PoigneesFaure, New pol, Curtiss
Reference ADEPEM : 018958
Tuyau vidange 2,30m 1240881704
Type: Tuyaux et duritesArthur martin, Electrolux, Faure
Reference ADEPEM : 047647
