Reference ADEPEM : 035761
Charniere de hublot l79c000a6
Type: CharnieresVedette, Brandt, Proline
Reference ADEPEM : 048920
Reference ADEPEM : 111588
Reference ADEPEM : 018667
Reference ADEPEM : 055848
Charniere de hublot 52x0100, l79e001a5
Reference ADEPEM : 047853
Reference ADEPEM : 063907
Soufflet de hublot l21b010i0
Reference ADEPEM : 039211
Pompe de vidange l71b014i1
Reference ADEPEM : 052008
Joint spi 37x62x12 l57a002a2
Reference ADEPEM : 069342
Joint spi 32x52x10 l57a001a4
Reference ADEPEM : 071005
Courroie 1184j5
Reference ADEPEM : 008426
Reference ADEPEM : 048025
Clip fixation cuve
Type: Colliers et clipsFagor, Brandt, Vedette
Reference ADEPEM : 064308
Bouchon de pompe
Type: BouchonsBrandt, Fagor, Vedette
Reference ADEPEM : 098420
Tuyau vidange 2,50m
Reference ADEPEM : 017905
Hublot verre l49a002b8
Reference ADEPEM : 040981
Durite boite-cuve lb5a001a3
Reference ADEPEM : 075873
Programmateur l20f027i6
Type: Minuteurs et programmateursFagor, Proline, Brandt
Reference ADEPEM : 042147
Antiparasite 0,47µf c00064559
Reference ADEPEM : 052059
Boite lessive liquide l63b000a7
Type: Distributeurs lessiveFagor, Brandt, Vedette
Reference ADEPEM : 066665
Durite cuve/pompe as0031774
Reference ADEPEM : 067065
Joint conduit d'air superieur
Type: JointsFagor, Brandt, De dietrich
Reference ADEPEM : 104178
Resistance 1850w le6s023a9
Type: ResistancesFagor, Brandt, Vedette
Reference ADEPEM : 059097
Type: HublotsVedette, Proline, Brandt
Reference ADEPEM : 048979
Cerclage hublot interieur
Reference ADEPEM : 040980
Cerclage hublot interieur 25164
Type: HublotsProline, Vedette, Kenwood
Reference ADEPEM : 051630
Interrupteur 6 cosses 481941029126
Type: Interrupteurs et switchWhirlpool, Faure, Zanussi
Reference ADEPEM : 006199
Renfort charniere
Type: CharnieresVedette, Proline, Kenwood
Reference ADEPEM : 051629
Collier 60-80mm
Reference ADEPEM : 043450
Type: ModulesFagor, Proline, Brandt
Reference ADEPEM : 057927
Potentiometre essorage
Type: Commutateurs et selecteursFagor, Brandt, Vedette
Reference ADEPEM : 062889
Resistance sechage 1400w
Type: ResistancesFagor, Brandt, De dietrich
Reference ADEPEM : 097922
Rondelle
Type: Bagues, ecrous et rondellesFagor, Brandt, Vedette
Reference ADEPEM : 101196
Soufflet de hublot l21b010c6
Type: JointsBrandt, Fagor, De dietrich
Reference ADEPEM : 068163
Support contrepoids
Type: Supports et fixationsFagor, Brandt, Vedette
Reference ADEPEM : 101195
Bague moteur
Type: Bagues, ecrous et rondellesFagor, Brandt, De dietrich
Reference ADEPEM : 104176
Collier arriere de soufflet
Reference ADEPEM : 069863
Collier de soufflet avant
Reference ADEPEM : 076456
Croisillon de tambour
Type: Roulements et paliersFagor, Brandt, Vedette
Reference ADEPEM : 124183
Cuve 45l, la0680500
Type: Cuves et tamboursFagor, Brandt, Vedette
Reference ADEPEM : 076694
Fixation
Reference ADEPEM : 055068
Joint conduit d'air inferieur
Type: JointsFagor, De dietrich, Brandt
Reference ADEPEM : 104180
Joint de rampe de sechage
Reference ADEPEM : 104177
Joint de thermostat
Reference ADEPEM : 069366
Moteur ventilateur m1398
Type: Ventilateurs et helicesFagor, Brandt, De dietrich
Reference ADEPEM : 104174
Type: PiedsFagor, Brandt, Vedette
Reference ADEPEM : 076494
Siphon lessive liquide
Type: DiversFagor, Brandt, Proline
Reference ADEPEM : 089331
Tambour
Reference ADEPEM : 078904
Tiroir lessive + boitier L48A019A5
Reference ADEPEM : 054332
Tole de protection
Type: DiversFagor, Brandt, Vedette
Reference ADEPEM : 065858
Turbine
Reference ADEPEM : 088539
Vanne anti-debordement
Type: ElectrovannesFagor, Brandt, De dietrich
Reference ADEPEM : 129456
Variateur temperature
Type: ModulesFagor, Proline, Vedette
Reference ADEPEM : 060533
Voyant rouge rond
Type: Lampes et ampoulesFagor, Vedette, Brandt
Reference ADEPEM : 037198
Kit joint de palier
Reference ADEPEM : 190762
Securite hublot zv445 l39a000i6
Reference ADEPEM : 034677
Thermostat 96°nc / 24°
Type: ThermostatsFagor, Brandt, Vedette
Reference ADEPEM : 048066
Chambre de compression lm3a005a3
Type: RepartiteurFagor, Brandt, Vedette
Reference ADEPEM : 097824
Pressostat 1 niveau
Type: PressostatsFagor, Vedette, Kenwood
Reference ADEPEM : 039034
Siphon la0300702
Type: DiversFagor, Vedette, Brandt
Reference ADEPEM : 085505
