Reference ADEPEM : 005886
Courroie 1225j5 = 5epj1225, 41021973
Type: CourroiesCandy, Hoover, Zerowatt
Reference ADEPEM : 092980
Sécurité de porte 49030389
Type: Securites et verrousCandy, Hoover, Rosieres
Reference ADEPEM : 055358
Amortisseur 120n 49043541, 41017170
Type: Amortisseurs et ressortsCandy, Brandt, Hoover
Reference ADEPEM : 107611
Bouchon de vidange 41021233
Type: BouchonsCandy, Hoover, Zerowatt
Reference ADEPEM : 097999
Aube de tambour 41021913, as0040544
Type: Aubes de tambourCandy, Hoover, Zerowatt
Reference ADEPEM : 082541
Amortisseur 120n 41017168
Type: Amortisseurs et ressortsCandy, Hoover, Brandt
Reference ADEPEM : 190883
Roulement 6203zz, 17x40x12mm
Reference ADEPEM : 030301
Roulement etanche 6205-2rs, 25x52x15mm
Type: Roulements et paliersHonda, Candy, Al-ko
Reference ADEPEM : 116975
Pompe de vidange b20-6b, 46003742
Type: PompesCandy, Hoover, Iberna
Reference ADEPEM : 095748
Sonde ctn 49015420
Type: Capteurs et sondesCandy, Hoover, Zerowatt
Reference ADEPEM : 092862
Condensateur 12,5µf 400v
Reference ADEPEM : 029938
Charniere habillage 92784297
Type: CharnieresCandy, Rosieres, Hoover
Reference ADEPEM : 026278
Courroie 1210j5, 1290775400
Reference ADEPEM : 037408
Charbons par 2 , 49028931 , 5x12,5x30
Type: Charbons moteurCandy, Ariston, Hoover
Reference ADEPEM : 046887
Electrovanne 2 voies, 41032538
Type: ElectrovannesCandy, Hoover, Iberna
Reference ADEPEM : 080387
Antiparasites 0,1µf 2x0,027µf
Reference ADEPEM : 058839
Poulie tambour d=278 41024467
Type: Pignons et pouliesCandy, Hoover, Zerowatt
Reference ADEPEM : 102698
Reference ADEPEM : 005890
Securite de porte da053 /da004, 46002826
Type: Securites et verrousCandy, Hoover, Iberna
Reference ADEPEM : 046494
Antiparasite 91200098
Reference ADEPEM : 100889
Pompe de vidange 9010341, 41019104
Type: PompesCandy, Hoover, Zerowatt
Reference ADEPEM : 119645
Thermoplongeur 1300w + sonde 41042459
Type: ResistancesCandy, Hoover, Zerowatt
Reference ADEPEM : 160298
Amortisseur 100n 70010336
Type: Amortisseurs et ressortsCandy, Hoover, Iberna
Reference ADEPEM : 168111
Bouchon de pompe 41004157
Reference ADEPEM : 073740
Reference ADEPEM : 030827
Goupille amortisseur 41017173
Type: Amortisseurs et ressortsCandy, Hoover, Zerowatt
Reference ADEPEM : 120558
Reference ADEPEM : 029939
Courroie 1233j5 = 5pj1233
Reference ADEPEM : 019144
Bouchon de pompe 91940540
Type: BouchonsCandy, Rosieres, Zerowatt
Reference ADEPEM : 026341
Module clavier 41041468
Type: ModulesCandy, Rosieres, Baumatic
Reference ADEPEM : 150118
Pompe de vidange, 49002228, 41005959
Reference ADEPEM : 056037
Securite t12 481927138287
Reference ADEPEM : 030920
Collier arriere de soufflet
Type: Colliers et clipsCandy, Hoover, Zerowatt
Reference ADEPEM : 129232
Durite condenseur
Type: Tuyaux et duritesCandy, Hoover, Rosieres
Reference ADEPEM : 098656
Support amortisseur
Type: Supports et fixationsCandy, Hoover, Rosieres
Reference ADEPEM : 185507
Thermoplongeur 1950w + sonde 41028717
Type: ResistancesCandy, Hoover, Rosieres
Reference ADEPEM : 025772
Joint de palier
Type: JointsCandy, Hoover, Iberna
Reference ADEPEM : 075026
Sonde ctn 49005297
Reference ADEPEM : 062913
Soufflet de hublot 41008852
Reference ADEPEM : 042138
Amortisseur 41009196
Type: Amortisseurs et ressortsMiele, Candy, Hoover
Reference ADEPEM : 061633
Anneau joint+v ring
Type: DiversCandy, Rosieres, First line
Reference ADEPEM : 025979
Carter ventilateur inferieur
Type: Boitiers et cartersCandy, Hoover, Rosieres
Reference ADEPEM : 125461
Ensemble 5 touches
Type: BoutonsCandy, Rosieres, Hoover
Reference ADEPEM : 166171
Filtre de pompe
Type: FiltresCandy, Hoover, Rosieres
Reference ADEPEM : 072902
Joint de filtre
Reference ADEPEM : 026050
Palier oppose poulie 81452674
Type: Roulements et paliersCandy, Miele, Rosieres
Reference ADEPEM : 042416
Pressostat lave vaisselle 2 niveaux
Type: PressostatsCandy, Rosieres
Reference ADEPEM : 025945
Ressort de crochet hublot
Reference ADEPEM : 083390
Silent-bloc
Reference ADEPEM : 026023
Tirant de lest beton
Type: DiversCandy, Rosieres, Zerowatt
Reference ADEPEM : 082555
Roulement 6202z, 15x35x11mm
Reference ADEPEM : 030302
Kit crochet hublot 91941759
Type: HublotsCandy, Rosieres, Progress
Reference ADEPEM : 071766
Electrovanne 2 voies 41018989
Type: ElectrovannesCandy, Hoover, Zerowatt
Reference ADEPEM : 081132
Joint 30x52x11/12,5
Reference ADEPEM : 044634
Manchette de cuve
Type: JointsCandy, Rosieres, Iberna
Reference ADEPEM : 024834
Poignee de hublot blanche
Type: PoigneesCandy, Rosieres, Brandt
Reference ADEPEM : 162366
Type: PressostatsCandy, Hoover, Rosieres
Reference ADEPEM : 147175
Type: Securites et verrousHoover, Candy, Rosieres
Reference ADEPEM : 055357
Touches de clavier
Type: BoutonsRosieres, Candy, Hoover
Reference ADEPEM : 154261
Vis de fixation poulie
Type: Visserie et emboutsCandy, Hoover, Zerowatt
Reference ADEPEM : 146387
Antiparasite 0,47µf+2x0.01µf
Type: CondensateursBosch, Candy, Siemens
Reference ADEPEM : 018021
Charniere habillage 43011965
Type: CharnieresRosieres
Reference ADEPEM : 201519
Courroie 3l474
Type: CourroiesCandy, Rosieres, Iberna
Reference ADEPEM : 025808
Courroie 3l490 / 3l493
Type: CourroiesAriston, Markling, Candy
Reference ADEPEM : 001812
Module clavier
Type: ModulesCandy, Hoover, Brandt
Reference ADEPEM : 133700
Selecteur fonctions
Type: Commutateurs et selecteursHoover, Candy, Rosieres
Reference ADEPEM : 084330
Sonde sechage, 41032956
Reference ADEPEM : 073643
Thermoplongeur 1950w + sonde 41026962
Reference ADEPEM : 106777
Bobine tachymetrique 91950881
Type: Bobines et filsCandy, Rosieres, Hoover
Reference ADEPEM : 171777
Cable ouverture de porte 41019240
Type: Cables et cordonsRosieres
Reference ADEPEM : 211319
Carter superieur sechage
Reference ADEPEM : 111997
Cerclage de hublot exterieur 43011750
Type: PortesRosieres
Reference ADEPEM : 207103
Charnieres d'habillage 41026810
Reference ADEPEM : 130616
Courroie 3l492 92130566
Type: CourroiesCandy, Iberna, Rosieres
Reference ADEPEM : 025802
Crochet hublot metal
Type: HublotsCandy, Rosieres, Hoover
Reference ADEPEM : 036302
Type: ElectrovannesHoover, Candy, Far
Reference ADEPEM : 080141
Joint de flasque cuve
Reference ADEPEM : 048711
Joint de palier (grand)
Type: JointsCandy, Rosieres, Kelvinator
Reference ADEPEM : 026020
Kit crochet hublot
Reference ADEPEM : 069176
Moteur ventilateur p/n m3934
Type: Ventilateurs et helicesCandy, Hoover, Rosieres
Reference ADEPEM : 096083
Poignee de hublot 43026519
Reference ADEPEM : 210170
Resistance 1950w 91201546
Reference ADEPEM : 055368
Retardateur ouverture
Reference ADEPEM : 025790
Type: JointsHoover, Candy, Rosieres
Reference ADEPEM : 083291
Tableau de commande + capteur 43016106
Type: ClaviersRosieres
Reference ADEPEM : 212257
Bobine tachymetrique 49000464
Reference ADEPEM : 079011
Contre poids
Type: DiversCandy, Hoover, Iberna
Reference ADEPEM : 126341
Contre poids superieur
Type: DiversCandy, Hoover, Rosieres
Reference ADEPEM : 145039
Corps de filtre 49002227
Reference ADEPEM : 038330
Durite condenseur 43017151
Reference ADEPEM : 151331
Durite electrovanne l=250
Reference ADEPEM : 181046
Electrovanne 3 voies 41013616
Type: ElectrovannesHoover, Candy, Rosieres
Reference ADEPEM : 101684
Joint de palier
Reference ADEPEM : 042415
Module de clavier
Type: ModulesCandy, Rosieres, Hoover
Reference ADEPEM : 115988
Module interface 41021535
Type: ModulesCandy, Hoover, Rosieres
Reference ADEPEM : 124389
Pied arriere
Type: PiedsCandy, Hoover, Rosieres
Reference ADEPEM : 042024
Thermostat de securite 180° 41034167
Type: ThermostatsCandy, Hoover, Rosieres
Reference ADEPEM : 132830
Thermostat de sécurité double
Type: ThermostatsCandy, Rosieres, Iberna
Reference ADEPEM : 025784
