Reference ADEPEM : 029992
Courroie 1225j5 = 5epj1225, 41021973
Type: CourroiesCandy, Hoover, Zerowatt
Reference ADEPEM : 092980
Sécurité de porte 49030389
Type: Securites et verrousCandy, Hoover, Rosieres
Reference ADEPEM : 055358
Bouchon de vidange 41021233
Type: BouchonsCandy, Hoover, Zerowatt
Reference ADEPEM : 097999
Aube de tambour 41021913, as0040544
Type: Aubes de tambourCandy, Hoover, Zerowatt
Reference ADEPEM : 082541
Roulement 6203zz, 17x40x12mm
Reference ADEPEM : 030301
Soufflet de hublot 43019185
Type: JointsCandy, Hoover, Zerowatt
Reference ADEPEM : 088470
Bougie rcj7y
Reference ADEPEM : 135835
Sonde ctn 49015420
Type: Capteurs et sondesCandy, Hoover, Zerowatt
Reference ADEPEM : 092862
Condensateur 12,5µf 400v
Reference ADEPEM : 029938
Ressort de cuve, l=178, 41031863
Type: Amortisseurs et ressortsCandy, Hoover, Zerowatt
Reference ADEPEM : 133938
Bol moulinette
Type: BolsMoulinex, De dietrich, Zerowatt
Reference ADEPEM : 024910
Courroie 1210j5, 1290775400
Reference ADEPEM : 037408
Couteau
Type: Lames et couteauxMoulinex, De dietrich, Zerowatt
Reference ADEPEM : 024905
Thermostat 320° 71x1924, 55.19062.800
Type: ThermostatsSauter, Brandt, De dietrich
Reference ADEPEM : 023543
Pompe de vidange 72886, 41018403
Type: PompesCandy, Hoover, Zerowatt
Reference ADEPEM : 092603
Thermostat four 818731063
Type: ThermostatsRosieres, Sauter, Brandt
Reference ADEPEM : 024033
Poulie tambour d=278 41024467
Type: Pignons et pouliesCandy, Hoover, Zerowatt
Reference ADEPEM : 102698
Antiparasite 91200098
Reference ADEPEM : 100889
Pompe de vidange 9010341, 41019104
Reference ADEPEM : 119645
Thermoplongeur 1300w + sonde 41042459
Type: ResistancesCandy, Hoover, Zerowatt
Reference ADEPEM : 160298
Couvercle
Type: Capots et couverclesMoulinex, De dietrich, Zerowatt
Reference ADEPEM : 024907
Bouchon de pompe 41004157
Reference ADEPEM : 073740
Goupille amortisseur 41017173
Reference ADEPEM : 120558
Pressostat 41035075
Type: PressostatsCandy, Hoover, Zerowatt
Reference ADEPEM : 116094
Thermoplongeur, 2200w + sonde, 41029722
Type: ResistancesHoover, Candy, Zerowatt
Reference ADEPEM : 109671
Reference ADEPEM : 029939
Courroie 1233j5 = 5pj1233
Reference ADEPEM : 019144
Bouchon de pompe 91940540
Type: BouchonsCandy, Rosieres, Zerowatt
Reference ADEPEM : 026341
Chaine 0regon - 1,5mm - 21bpx072e
Type: Chaines et guides chaineEcho, Husqvarna, Bestgreen
Reference ADEPEM : 139089
Chapeau bruleur d=94, 77x0951
Type: BruleursDe dietrich, Siemens, Braun
Reference ADEPEM : 024698
Module de commande 41041465
Type: ModulesCandy, Hoover, Iberna
Reference ADEPEM : 162544
Ressort de poignee
Type: Amortisseurs et ressortsRosieres, Candy, Hoover
Reference ADEPEM : 080664
Collier arriere de soufflet
Type: Colliers et clipsCandy, Hoover, Zerowatt
Reference ADEPEM : 129232
Courroie 1940h8
Type: CourroiesOcean, Vedette, Nogamatic
Reference ADEPEM : 030001
Thermoplongeur 1950w + sonde 41028717
Type: ResistancesCandy, Hoover, Rosieres
Reference ADEPEM : 025772
Courroie 1231h/1230h8 1294240203
Reference ADEPEM : 055581
Durite cuve/pompe 41001597
Type: Tuyaux et duritesCandy, Hoover, Zerowatt
Reference ADEPEM : 025815
Sonde ctn 49005297
Reference ADEPEM : 062913
Aube de tambour l=15,4cm 41021914
Reference ADEPEM : 080991
Bougie + fil 810 mm
Type: Bougies et electrodesDe dietrich, Moulinex, Babyliss
Reference ADEPEM : 027839
Filtre de pompe
Type: FiltresCandy, Hoover, Rosieres
Reference ADEPEM : 072902
Joint de filtre
Reference ADEPEM : 026050
Joint spi 30x47x10 92445535
Type: JointsCandy, Zerowatt, Oleo-mac
Reference ADEPEM : 052671
Silent-bloc
Reference ADEPEM : 026023
Tirant de lest beton
Type: DiversCandy, Rosieres, Zerowatt
Reference ADEPEM : 082555
Roulement 6202z, 15x35x11mm
Reference ADEPEM : 030302
Brosse combinee d=35
Type: Brosses et suceursMoulinex, Tornado, Hoover
Reference ADEPEM : 028824
Commutateur 46.27266.500 342752401/6
Type: Commutateurs et selecteursFaure, Brandt, Sauter
Reference ADEPEM : 030230
Collier avant fixation soufflet 41018408
Reference ADEPEM : 120368
Joint de poulie
Type: JointsVedette, Ocean, Nogamatic
Reference ADEPEM : 019864
Ecrou de guide
Type: Bagues, ecrous et rondellesStihl, Zerowatt
Reference ADEPEM : 189863
Electrovanne 2 voies 41018989
Type: ElectrovannesCandy, Hoover, Zerowatt
Reference ADEPEM : 081132
Hublot verre seul
Type: HublotsCandy, Hoover, Zerowatt
Reference ADEPEM : 083151
Type: PressostatsCandy, Hoover, Rosieres
Reference ADEPEM : 147175
Type: Securites et verrousHoover, Candy, Rosieres
Reference ADEPEM : 055357
Vis de fixation poulie
Type: Visserie et emboutsCandy, Hoover, Zerowatt
Reference ADEPEM : 146387
Antiparasite 0,47µf+2x0.01µf
Type: CondensateursBosch, Candy, Siemens
Reference ADEPEM : 018021
Courroie 3l474
Type: CourroiesCandy, Rosieres, Iberna
Reference ADEPEM : 025808
Crochet de hublot + ressort 49007928
Reference ADEPEM : 067594
Injecteurs butane-propane 92x1914
Type: Buses et injecteursDe dietrich, Zerowatt
Reference ADEPEM : 057902
Kit 10 tournevis de reglage carburateurs
Type: DiversHusqvarna, Stihl, Tck garden
Reference ADEPEM : 203968
Moteur mca61/64 - 148/cy23
Type: MoteursCandy, Hoover, Zerowatt
Reference ADEPEM : 177451
Programmateur ec2001.01
Type: Minuteurs et programmateursCandy, Hoover, Iberna
Reference ADEPEM : 064094
Sacs aspirateur par 4
Type: SacsTornado, Moulinex, De dietrich
Reference ADEPEM : 028667
Selecteur fonctions
Type: Commutateurs et selecteursHoover, Candy, Rosieres
Reference ADEPEM : 084330
Boitier inferieur tiroir lessive
Type: Distributeurs lessiveCandy, Hoover, Zerowatt
Reference ADEPEM : 102118
Courroie 1215h8
Reference ADEPEM : 097441
Courroie 3l492 92130566
Type: CourroiesCandy, Iberna, Rosieres
Reference ADEPEM : 025802
Reference ADEPEM : 102291
Durite cuve-pompe 41021806
Reference ADEPEM : 081004
Hublot en verre
Reference ADEPEM : 117686
Injecteurs gaz naturel
Type: Buses et injecteursDe dietrich, Zerowatt, Thomson
Reference ADEPEM : 023701
Interrupteur 6 cosses 92742816
Type: Interrupteurs et switchCandy, Rosieres, Faure
Reference ADEPEM : 026255
Moteur
Type: MoteursCandy, Hoover, Rosieres
Reference ADEPEM : 087718
Resistance sole 2200w
Type: ResistancesDe dietrich, Zerowatt, Braun
Reference ADEPEM : 026633
Thermoplongeur 1850w
Type: ResistancesCandy, Hoover, Iberna
Reference ADEPEM : 038343
Bobine tachymetrique 49000464
Reference ADEPEM : 079011
Cable d'alimentation
Type: Cables et cordonsCandy, Hoover, Rosieres
Reference ADEPEM : 084529
Cerclage interieur de hublot
Reference ADEPEM : 113825
Chaine oregon, série 0.325, 75exl066e
Type: Chaines et guides chaineStihl, Astoria, Indesit
Reference ADEPEM : 213963
Charniere de hublot
Type: CharnieresCandy, Hoover, Zerowatt
Reference ADEPEM : 131589
Charnières poignée de hublot
Type: CharnieresZerowatt, Otsein
Reference ADEPEM : 135477
Corps de filtre 49002227
Type: DiversCandy, Hoover, Rosieres
Reference ADEPEM : 038330
Courroie 1133j4
Type: CourroiesCandy, Iberna, Hoover
Reference ADEPEM : 049927
Courroie 1148j4
Type: CourroiesCandy, Zerowatt
Reference ADEPEM : 109750
Croisillon de tambour
Type: Roulements et paliersZerowatt, Candy
Reference ADEPEM : 109702
Durite de purge
Reference ADEPEM : 120294
Enjoliveur top droit
Type: Capots et couverclesCandy, Hoover, Zerowatt
Reference ADEPEM : 096205
Joint de cuve
Reference ADEPEM : 026021
Joint sonde thermostat
Reference ADEPEM : 061352
Type: ModulesHoover, Zerowatt
Reference ADEPEM : 084327
Patin amortisseur 92697838
Type: PiedsCandy, Rosieres, Hoover
Reference ADEPEM : 026200
Pied arriere
Type: PiedsCandy, Hoover, Rosieres
Reference ADEPEM : 042024
Pignon a bague 7 dents .325"
Type: Pignons et pouliesPartner, Husqvarna, De dietrich
Reference ADEPEM : 189773
Reference ADEPEM : 111072
Securite de hublot
Type: Securites et verrousZerowatt, Iberna, Candy
Reference ADEPEM : 025670
Thermostat de sécurité double
Type: ThermostatsCandy, Rosieres, Iberna
Reference ADEPEM : 025784
Tiroir lessive
Type: Distributeurs lessiveCandy, Hoover, Rosieres
Reference ADEPEM : 073017
