Reference ADEPEM : 071219
Ampoule 15w e14 300°
Reference ADEPEM : 023507
Ampoule four 25w e14 300°
Reference ADEPEM : 023508
Roulette panier inferieur
Reference ADEPEM : 068761
Reference ADEPEM : 076419
Joint bas de porte 1527401002
Reference ADEPEM : 041333
Reference ADEPEM : 013193
Element chauffant 2000w 4055373700
Type: ResistancesA.e.g, Electrolux, Ikea
Reference ADEPEM : 168808
Reference ADEPEM : 059802
Reference ADEPEM : 068760
Tuyau vidange coude 2m
Reference ADEPEM : 046715
Reference ADEPEM : 057375
Reference ADEPEM : 036022
Reference ADEPEM : 041332
Pompe de vidange bpx2-14l
Reference ADEPEM : 187912
Reference ADEPEM : 102128
Type: Roues et roulettesA.e.g, Arthur martin, Faure
Reference ADEPEM : 036898
Module de puissance 8077075052
Reference ADEPEM : 141707
Condensateur 3µf 400v
Reference ADEPEM : 029931
Pompe de vidange, 140000604011
Type: PompesA.e.g, Electrolux, Ikea
Reference ADEPEM : 157104
Type: Roues et roulettesArthur martin, A.e.g, Faure
Reference ADEPEM : 036184
Sonde de temperature, 140000401061
Type: Capteurs et sondesElectrolux, A.e.g, Ikea
Reference ADEPEM : 177729
Reference ADEPEM : 048543
Boite produit 4071358131
Type: Distributeurs lessiveA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 021974
Microswitch 3 cosses 16a
Reference ADEPEM : 030961
Panier a couverts 1118401700
Type: Bacs et paniersA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 042528
Reference ADEPEM : 034485
Module de commande*
Type: ModulesElectrolux, Faure, Arthur martin
Reference ADEPEM : 137075
Reference ADEPEM : 060855
Electrovanne 1 voie 1170958209
Type: ElectrovannesArthur martin, Electrolux, Faure
Reference ADEPEM : 065589
Sonde temperature 1113368003
Type: Capteurs et sondesA.e.g, Electrolux, Arthur martin
Reference ADEPEM : 066105
Touche interrupteur marche arret
Type: BoutonsArthur martin
Reference ADEPEM : 065467
Tuyau vidange 2,50m
Reference ADEPEM : 017905
Bague de serrage 1250091004
Reference ADEPEM : 005244
Reference ADEPEM : 120158
Electrovanne 1 voie 55x8399
Reference ADEPEM : 030809
Durite pressostat 5m
Reference ADEPEM : 030280
Module de commande*
Type: ModulesFaure, Progress, Zanussi
Reference ADEPEM : 163971
Panier a couverts 1525593008
Reference ADEPEM : 074931
Panier inferieur 140133729099
Type: Bacs et paniersElectrolux, Faure, Zanussi
Reference ADEPEM : 125269
Type: Tubes et conduitsArthur martin, Faure, Electrolux
Reference ADEPEM : 091441
Fixation bras superieur 8070358018
Type: Supports et fixationsA.e.g, Electrolux, Ikea
Reference ADEPEM : 166351
Module de commande edw750*
Type: ModulesElectrolux, Arthur martin
Reference ADEPEM : 146444
Panier a couverts gris
Type: Bacs et paniersArthur martin, Zanussi, Electrolux
Reference ADEPEM : 068517
Pressostat 65/45 152818902/8
Reference ADEPEM : 070343
Joint alimentation de bras 11720410/4
Reference ADEPEM : 034269
Joint bas de porte l=400 152740110/1
Reference ADEPEM : 072304
Reference ADEPEM : 075295
Roulette de panier dx (droite)
Type: Roues et roulettesZanussi, Arthur martin, Electrolux
Reference ADEPEM : 063070
Roulette panier 50269748005
Type: Roues et roulettesFaure, Arthur martin, Zanussi
Reference ADEPEM : 017699
Tuyau aquastop 1,80 metres
Type: Tuyaux et duritesA.e.g, Arthur martin, Faure
Reference ADEPEM : 066119
Reference ADEPEM : 017904
Reference ADEPEM : 071320
Durite de resistance
Reference ADEPEM : 089887
Reference ADEPEM : 056074
Reference ADEPEM : 030676
Resistance 1800w , 49025127
Reference ADEPEM : 157271
Demi bague fixation bras
Type: DiversA.e.g, Arthur martin, Faure
Reference ADEPEM : 036527
Interrupteur marche / arret
Reference ADEPEM : 053073
Microswitch 3 cosses 1505019008
Type: Interrupteurs et switchBosch, Siemens, Arthur martin
Reference ADEPEM : 030964
Poignee blanche
Type: PoigneesFaure, Arthur martin
Reference ADEPEM : 052834
Serrure loquet 4055283925
Reference ADEPEM : 068949
Bras de lavage inferieur
Type: Bras de lavageA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 073660
Joint de thermostat c00014917
Type: JointsAriston, Indesit, De dietrich
Reference ADEPEM : 030385
Manche plastique
Reference ADEPEM : 084148
Module de puissance*
Type: ModulesA.e.g, Electrolux, Ikea
Reference ADEPEM : 166085
Poignee noire
Type: PoigneesArthur martin
Reference ADEPEM : 050892
Pompe de vidange 58967
Type: PompesA.e.g, Arthur martin, Faure
Reference ADEPEM : 063354
Roulette double
Type: Roues et roulettesFaure, Zanussi, Arthur martin
Reference ADEPEM : 061710
Tube alimentation bras superieur
Type: Tubes et conduitsA.e.g, Arthur martin, Faure
Reference ADEPEM : 046462
Boitier
Reference ADEPEM : 073876
Reference ADEPEM : 095475
Durite coude
Type: Tuyaux et duritesArthur martin, A.e.g, Electrolux
Reference ADEPEM : 092627
Filtre tamis lave vaisselle
Type: FiltresElectrolux, Arthur martin
Reference ADEPEM : 059949
Fixation roulette 150956010/6
Type: Supports et fixationsElectrolux, Arthur martin
Reference ADEPEM : 073960
Joint bouchon bac sel 150326900/1
Type: JointsArthur martin, Electrolux
Reference ADEPEM : 202466
Reference ADEPEM : 049750
Joint de cuvette 5065923100/0
Reference ADEPEM : 058594
Joint filtre (grand)
Type: JointsZanussi, Arthur martin, Faure
Reference ADEPEM : 037606
Joint plaque de fond
Reference ADEPEM : 062283
Joint torique de cuve
Reference ADEPEM : 130449
Module de commande edw1100* 1113310526
Reference ADEPEM : 124098
Module electronique
Type: ModulesArthur martin
Reference ADEPEM : 065210
Module electronique edw*
Type: ModulesZanussi, Arthur martin, Electrolux
Reference ADEPEM : 191024
Module electronique edw1100
Reference ADEPEM : 173391
Pied reglable 1250119029
Reference ADEPEM : 017304
Poignee blanche
Reference ADEPEM : 065649
Pompe cyclage
Type: PompesArthur martin, A.e.g, Electrolux
Reference ADEPEM : 033590
Pompe cyclage+turbine
Type: PompesArthur martin, Faure, Zanussi
Reference ADEPEM : 017707
Type: PompesFaure, Arthur martin, Zanussi
Reference ADEPEM : 037642
Type: PressostatsFaure, Zanussi, Arthur martin
Reference ADEPEM : 039332
Repartiteur d'eau 111813950/8
Type: RepartiteurA.e.g, Arthur martin, Faure
Reference ADEPEM : 066901
Roulette panier 50659337005
Type: Roues et roulettesArthur martin, Faure, Electrolux
Reference ADEPEM : 017791
Roulette superieure
Type: Roues et roulettesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 072148
Support roulettes reglable droit
Type: Supports et fixationsElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 103767
Support superieur bras cyclage
Type: Supports et fixationsA.e.g, Arthur martin, Faure
Reference ADEPEM : 055843
Switch 2 cosses securite porte
Type: Interrupteurs et switchArthur martin, Electrolux, Indesit
Reference ADEPEM : 004033
Touche blanche
Type: BoutonsFaure, Arthur martin, Zanussi
Reference ADEPEM : 061738
Trappe produit de rinçage
Reference ADEPEM : 182165
Traverse avant
Reference ADEPEM : 091622
Reference ADEPEM : 089895
