Reference ADEPEM : 071219
Roulette panier inferieur
Reference ADEPEM : 068761
Reference ADEPEM : 076419
Joint bas de porte 1527401002
Reference ADEPEM : 041333
Reference ADEPEM : 112972
Reference ADEPEM : 068760
Reference ADEPEM : 047417
Tuyau vidange coude 2m
Reference ADEPEM : 046715
Durite electrovanne 1m, d=10
Reference ADEPEM : 030286
Reference ADEPEM : 036022
Bras de lavage inferieur 34421173
Type: Bras de lavageCurtiss, Proline, Thomson
Reference ADEPEM : 197835
Joint bas de porte l=54cm 34420055
Type: JointsValberg, California, Candy
Reference ADEPEM : 082579
Reference ADEPEM : 041332
Pompe de vidange bpx2-14l
Reference ADEPEM : 187912
Joint tour de porte l=174cm
Reference ADEPEM : 114948
Panier a couverts 31x5348
Reference ADEPEM : 009538
Panier inferieur 672000803080
Reference ADEPEM : 131514
Pompe de vidange as0042300
Reference ADEPEM : 205656
Ecrou du repartiteur
Reference ADEPEM : 120155
Reference ADEPEM : 060855
Electrovanne 1 voie 1170958209
Type: ElectrovannesArthur martin, Electrolux, Faure
Reference ADEPEM : 065589
Reference ADEPEM : 120158
Reference ADEPEM : 009579
Pressostat 65/45 152818902/8
Reference ADEPEM : 070343
Serrure + poignee blanche
Type: Securites et verrousFar, Aya, Continental edison
Reference ADEPEM : 138421
Reference ADEPEM : 159020
Conduit alimentation
Reference ADEPEM : 071320
Durite de resistance
Reference ADEPEM : 089887
Reference ADEPEM : 056074
Pompe de cyclage as0018883
Reference ADEPEM : 193864
Resistance 1800w , 49025127
Reference ADEPEM : 157271
Verrou de porte
Type: Securites et verrousBrandt, Continental edison, De dietrich
Reference ADEPEM : 146460
Reference ADEPEM : 009585
Type: Bras de lavageCalifornia, Continental edison, Aya
Reference ADEPEM : 083117
Boitier
Reference ADEPEM : 073876
Interrupteur marche-arret
Reference ADEPEM : 009564
Reference ADEPEM : 049750
Kit turbine+joint
Reference ADEPEM : 034372
Pompe de cyclage
Type: PompesCurtiss, Proline, Urania
Reference ADEPEM : 135094
Roulette panier
Type: Supports et fixationsCurtiss, Far, Baumatic
Reference ADEPEM : 147480
Touche depart/pause
Type: BoutonsCurtiss
Reference ADEPEM : 151669
Traverse avant
Reference ADEPEM : 091622
Panier a couverts 1525593008
Reference ADEPEM : 074931
Reference ADEPEM : 075295
Bras de lavage superieur, 1526520034
Type: Bras de lavageArthur martin, Zanussi, Faure
Reference ADEPEM : 078205
Type: ElectrovannesFaure, Zanussi, Arthur martin
Reference ADEPEM : 036554
Roulettes de rail par 4, 50299970009
Reference ADEPEM : 182150
Bloc hydraulique 152795712/8
Type: DiversA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 109800
Reference ADEPEM : 120160
Type: Bras de lavageZanussi, Faure, Arthur martin
Reference ADEPEM : 045843
Grand couvercle de la boite produit
Type: Capots et couverclesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 085254
Panier superieur
Type: Bacs et paniersContinental edison, Curtiss, Far
Reference ADEPEM : 118587
Ressort poignee
Type: Amortisseurs et ressortsFaure, Zanussi, Arthur martin
Reference ADEPEM : 061734
Bouton marche - arret
Type: BoutonsCurtiss, Proline, Urania
Reference ADEPEM : 140087
Cliquet
Type: DiversA.e.g, Electrolux, Zanussi
Reference ADEPEM : 061694
Condensateur 3µf
Reference ADEPEM : 110998
Conduit bras superieur
Type: Tubes et conduitsFaure, Zanussi, Arthur martin
Reference ADEPEM : 042097
Couvercle liquide rincage
Reference ADEPEM : 095570
Durite produit adoucissant
Reference ADEPEM : 076356
Electrovanne
Type: ElectrovannesThomson, Proline, Valberg
Reference ADEPEM : 168684
Embout de glissiere
Type: Visserie et emboutsA.e.g, Electrolux, Faure
Reference ADEPEM : 035369
Interrupteur marche/arret 4 cosses
Type: Interrupteurs et switchFar, Aya, Curtiss
Reference ADEPEM : 152462
Joint collecteur 5028265000/6
Reference ADEPEM : 060856
Joint de conduit 152311901/2
Reference ADEPEM : 049027
Panier superieur
Reference ADEPEM : 154785
Panier superieur
Type: Bacs et paniersProline, Aya, Continental edison
Reference ADEPEM : 122291
Sonde temperature
Type: Capteurs et sondesProline, Oceanic, Curtiss
Reference ADEPEM : 112103
Adoucisseur
Type: AdoucisseurA.e.g, Electrolux, Arthur martin
Reference ADEPEM : 081878
Reference ADEPEM : 113263
Bouchon de bac a sel
Type: BouchonsArthur martin, A.e.g, Electrolux
Reference ADEPEM : 080689
Type: Bras de lavageSelecline, Curtiss, Valberg
Reference ADEPEM : 136816
Durite bac pompe de vidange
Type: Tuyaux et duritesA.e.g, Arthur martin, Zanussi
Reference ADEPEM : 073473
Durite "y"
Reference ADEPEM : 068437
Fermeture de porte
Type: Securites et verrousA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 138554
Interrupteur 4 cosses marche / arret
Type: Interrupteurs et switchContinental edison, Curtiss, Proline
Reference ADEPEM : 119111
Joint alimentation bras superieur
Type: JointsProline, Curtiss, King d'home
Reference ADEPEM : 150321
Microswitch 2 cosses porte
Type: Interrupteurs et switchA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 061717
Panier inferieur
Type: Bacs et paniersProline, Curtiss, Tecnolec
Reference ADEPEM : 140201
Pompe de cyclage 4055070025
Type: PompesFaure, Electrolux, Zanussi
Reference ADEPEM : 085810
Pressostat 140/120
Type: PressostatsProline, Curtiss, Selecline
Reference ADEPEM : 131050
Serrure de porte
Type: Securites et verrousElectrolux, A.e.g, Faure
Reference ADEPEM : 124469
Switch de flotteur
Type: Interrupteurs et switchBrandt, Whirlpool, Fagor
Reference ADEPEM : 161044
Thermoplongeur 1800w , as0033456
Type: ResistancesBrandt, Whirlpool, Continental edison
Reference ADEPEM : 184177
Reference ADEPEM : 144222
Adoucisseur complet
Type: AdoucisseurFaure, Zanussi, Arthur martin
Reference ADEPEM : 045559
Anneau clip bouton programmateur
Type: DiversFaure, Electrolux, Zanussi
Reference ADEPEM : 082889
Arrivee d'eau superieure
Type: DiversBrandt, Thomson, Vedette
Reference ADEPEM : 009508
Bouchon bac sel
Type: BouchonsVedette, Brandt, De dietrich
Reference ADEPEM : 009519
Durite raccord cuve-resistance
Reference ADEPEM : 156968
Electrovanne (iwms2)
Type: ElectrovannesZanussi, Faure, Arthur martin
Reference ADEPEM : 061730
Glissiere de panier superieur
Type: DiversArthur martin, Zanussi, Faure
Reference ADEPEM : 065334
Joint d'adoucisseur
Type: JointsArthur martin, Faure, A.e.g
Reference ADEPEM : 063919
Joint de collecteur
Type: JointsA.e.g, Arthur martin, Zanussi
Reference ADEPEM : 108175
Panier inferieur
Type: Bacs et paniersFaure, Zanussi, Electrolux
Reference ADEPEM : 045551
Panier inferieur
Type: Bacs et paniersCurtiss, Far, Highone
Reference ADEPEM : 198943
Pied avant reglable
Type: PiedsElectrolux, Faure, Arthur martin
Reference ADEPEM : 122219
Plinthe inferieure
Reference ADEPEM : 080864
Pressostat securite 123-98 1528189127
Reference ADEPEM : 090901
Resistance
Type: ResistancesCurtiss
Reference ADEPEM : 212046
Support tasses gris
Type: Supports et fixationsFaure, Zanussi, Arthur martin
Reference ADEPEM : 112558
Thermoplongeur 2100w
Type: ResistancesZanussi, Faure, Electrolux
Reference ADEPEM : 017690
Thermostat 75°nc
Type: ThermostatsZanussi, Faure, Arthur martin
Reference ADEPEM : 042647
Thermostat 80°nc/72°nc
Type: ThermostatsBrandt, Vedette, Thomson
Reference ADEPEM : 009565
Thermostat lave vaisselle
Type: ThermostatsCurtiss
Reference ADEPEM : 162777
Tube alimentation
Type: Tubes et conduitsProline, Glem, Curtiss
Reference ADEPEM : 165201
