Reference ADEPEM : 071219
Roulette panier inferieur
Reference ADEPEM : 068761
Reference ADEPEM : 076419
Joint bas de porte 1527401002
Reference ADEPEM : 041333
Reference ADEPEM : 013193
Element chauffant 2000w 4055373700
Type: ResistancesA.e.g, Electrolux, Ikea
Reference ADEPEM : 168808
Reference ADEPEM : 059802
Reference ADEPEM : 068760
Tuyau vidange coude 2m
Reference ADEPEM : 046715
Reference ADEPEM : 036022
Reference ADEPEM : 041332
Pompe de vidange bpx2-14l
Reference ADEPEM : 187912
Reference ADEPEM : 102128
Type: Roues et roulettesA.e.g, Arthur martin, Faure
Reference ADEPEM : 036898
Condensateur 5µf 400v
Reference ADEPEM : 029933
Panier a couverts 31x5348
Reference ADEPEM : 009538
Module de puissance 8077075052
Reference ADEPEM : 141707
Type: Roues et roulettesArthur martin, A.e.g, Faure
Reference ADEPEM : 036184
Pompe de vidange bpx2-28l 140000443022
Type: PompesA.e.g, Electrolux, Progress
Reference ADEPEM : 115274
Sonde de temperature, 140000401061
Type: Capteurs et sondesElectrolux, A.e.g, Ikea
Reference ADEPEM : 177729
Boite produit 4071358131
Type: Distributeurs lessiveA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 021974
Reference ADEPEM : 034485
Module de commande*
Type: ModulesElectrolux, Faure, Arthur martin
Reference ADEPEM : 137075
Ecrou du repartiteur
Reference ADEPEM : 120155
Reference ADEPEM : 060855
Electrovanne 1 voie 1170958209
Type: ElectrovannesArthur martin, Electrolux, Faure
Reference ADEPEM : 065589
Tuyau vidange 1,50m coude
Reference ADEPEM : 017906
Sonde temperature 1113368003
Type: Capteurs et sondesA.e.g, Electrolux, Arthur martin
Reference ADEPEM : 066105
Tuyau vidange 2,50m
Reference ADEPEM : 017905
Bague de serrage 1250091004
Reference ADEPEM : 005244
Reference ADEPEM : 120158
Electrovanne 1 voie 55x8399
Reference ADEPEM : 030809
Reference ADEPEM : 009579
Module de commande*
Type: ModulesFaure, Progress, Zanussi
Reference ADEPEM : 163971
Type: Tubes et conduitsArthur martin, Faure, Electrolux
Reference ADEPEM : 091441
Panier a couverts gris
Type: Bacs et paniersArthur martin, Zanussi, Electrolux
Reference ADEPEM : 068517
Pressostat 65/45 152818902/8
Reference ADEPEM : 070343
Joint alimentation de bras 11720410/4
Reference ADEPEM : 034269
Joint bas de porte l=400 152740110/1
Reference ADEPEM : 072304
Roulette de panier dx (droite)
Type: Roues et roulettesZanussi, Arthur martin, Electrolux
Reference ADEPEM : 063070
Roulette panier 50269748005
Type: Roues et roulettesFaure, Arthur martin, Zanussi
Reference ADEPEM : 017699
Tuyau aquastop 1,80 metres
Type: Tuyaux et duritesA.e.g, Arthur martin, Faure
Reference ADEPEM : 066119
Reference ADEPEM : 017904
Reference ADEPEM : 071320
Durite de resistance
Reference ADEPEM : 089887
Reference ADEPEM : 056074
Module electronique edw150*
Reference ADEPEM : 128574
Resistance 1800w , 49025127
Reference ADEPEM : 157271
Demi bague fixation bras
Type: DiversA.e.g, Arthur martin, Faure
Reference ADEPEM : 036527
Interrupteur marche / arret
Reference ADEPEM : 053073
Poignee blanche
Type: PoigneesFaure, Arthur martin
Reference ADEPEM : 052834
Bras de lavage inferieur
Type: Bras de lavageA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 073660
Manche plastique
Reference ADEPEM : 084148
Pompe de vidange 58967
Type: PompesA.e.g, Arthur martin, Faure
Reference ADEPEM : 063354
Roulette double
Type: Roues et roulettesFaure, Zanussi, Arthur martin
Reference ADEPEM : 061710
Tube alimentation bras superieur
Type: Tubes et conduitsA.e.g, Arthur martin, Faure
Reference ADEPEM : 046462
Boitier
Reference ADEPEM : 073876
Reference ADEPEM : 095475
Element de pulverisation inferieur
Type: Bras de lavageA.e.g, Electrolux, Zanussi
Reference ADEPEM : 197555
Glissiere habillage
Type: DiversElectrolux, Candy, Rosieres
Reference ADEPEM : 017401
Reference ADEPEM : 049750
Joint de cuvette 5065923100/0
Reference ADEPEM : 058594
Joint filtre (grand)
Type: JointsZanussi, Arthur martin, Faure
Reference ADEPEM : 037606
Joint torique de cuve
Reference ADEPEM : 130449
Kit turbine+joint
Reference ADEPEM : 034372
Kit turbine pompe cyclage
Type: Ventilateurs et helicesFaure, Zanussi, Arthur martin
Reference ADEPEM : 038535
Type: ModulesFaure
Reference ADEPEM : 112218
Module de commande edw1100* 1113310526
Reference ADEPEM : 124098
Module electronique
Type: ModulesFaure
Reference ADEPEM : 097062
Panier superieur
Type: Bacs et paniersFaure
Reference ADEPEM : 093585
Pied reglable 1250119029
Reference ADEPEM : 017304
Pompe cyclage+turbine
Type: PompesArthur martin, Faure, Zanussi
Reference ADEPEM : 017707
Type: PompesFaure, Arthur martin, Zanussi
Reference ADEPEM : 037642
Type: PressostatsFaure, Zanussi, Arthur martin
Reference ADEPEM : 039332
Repartiteur d'eau 111813950/8
Type: RepartiteurA.e.g, Arthur martin, Faure
Reference ADEPEM : 066901
Ressort de porte
Type: Amortisseurs et ressortsA.e.g, Arthur martin, Faure
Reference ADEPEM : 090990
Roulette panier 50659337005
Type: Roues et roulettesArthur martin, Faure, Electrolux
Reference ADEPEM : 017791
Roulette superieure
Type: Roues et roulettesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 072148
Support superieur bras cyclage
Type: Supports et fixationsA.e.g, Arthur martin, Faure
Reference ADEPEM : 055843
Switch 2 cosses securite porte
Type: Interrupteurs et switchArthur martin, Electrolux, Indesit
Reference ADEPEM : 004033
Touche blanche
Type: BoutonsFaure, Arthur martin, Zanussi
Reference ADEPEM : 061738
Trappe produit de rinçage
Reference ADEPEM : 182165
Traverse avant
Reference ADEPEM : 091622
Reference ADEPEM : 089895
Pressostat 140000554083
Reference ADEPEM : 156588
Panier a couverts 1525593008
Reference ADEPEM : 074931
Panier inferieur 140133729099
Type: Bacs et paniersElectrolux, Faure, Zanussi
Reference ADEPEM : 125269
Reference ADEPEM : 075295
Serrure loquet 4055283925
Reference ADEPEM : 068949
Module de puissance 140059122220*
Reference ADEPEM : 212314
Boite produits 812890061
Reference ADEPEM : 040328
Bras de lavage superieur, 1526520034
Type: Bras de lavageArthur martin, Zanussi, Faure
Reference ADEPEM : 078205
Sonde de temperature 3792171021
Type: Capteurs et sondesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 051617
Bras superieur + support
Type: Bras de lavageA.e.g, Arthur martin, Faure
Reference ADEPEM : 037907
Durite bac pompe cyclage 1118455102
Reference ADEPEM : 073472
Type: ElectrovannesFaure, Zanussi, Arthur martin
Reference ADEPEM : 036554
Reference ADEPEM : 059277
Roulettes de rail par 4, 50299970009
Reference ADEPEM : 182150
Tuyau aquastop 5029566300/4
Reference ADEPEM : 065032
Bloc hydraulique 152795712/8
Type: DiversA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 109800
Panier a couverts 1118228103
Type: Bacs et paniersArthur martin, Electrolux, Faure
Reference ADEPEM : 043912
Pompe de cyclage
Type: PompesArthur martin, Electrolux, A.e.g
Reference ADEPEM : 064077
