Reference ADEPEM : 071219
Roulette panier inferieur
Reference ADEPEM : 068761
Reference ADEPEM : 076419
Joint bas de porte 1527401002
Reference ADEPEM : 041333
Guide panier as0000006
Type: Bacs et paniersA.e.g, Electrolux, Fagor
Reference ADEPEM : 065706
Element chauffant 2000w 4055373700
Type: ResistancesA.e.g, Electrolux, Ikea
Reference ADEPEM : 168808
Reference ADEPEM : 059802
Reference ADEPEM : 068760
Reference ADEPEM : 036022
Reference ADEPEM : 041332
Pompe de vidange bpx2-14l
Reference ADEPEM : 187912
Reference ADEPEM : 102128
Module de puissance 8077075052
Reference ADEPEM : 141707
Pompe de vidange bpx2-28l 140000443022
Type: PompesA.e.g, Electrolux, Progress
Reference ADEPEM : 115274
Sonde de temperature, 140000401061
Type: Capteurs et sondesElectrolux, A.e.g, Ikea
Reference ADEPEM : 177729
Boite produit 4071358131
Type: Distributeurs lessiveA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 021974
Ecrou du repartiteur
Reference ADEPEM : 120155
Reference ADEPEM : 060855
Sonde temperature 1113368003
Type: Capteurs et sondesA.e.g, Electrolux, Arthur martin
Reference ADEPEM : 066105
Reference ADEPEM : 120158
Module de commande*
Type: ModulesFaure, Progress, Zanussi
Reference ADEPEM : 163971
Type: Tubes et conduitsArthur martin, Faure, Electrolux
Reference ADEPEM : 091441
Fixation bras superieur 8070358018
Type: Supports et fixationsA.e.g, Electrolux, Ikea
Reference ADEPEM : 166351
Panier a couverts gris
Type: Bacs et paniersArthur martin, Zanussi, Electrolux
Reference ADEPEM : 068517
Pressostat 65/45 152818902/8
Reference ADEPEM : 070343
Joint bas de porte l=400 152740110/1
Reference ADEPEM : 072304
Durite de resistance
Reference ADEPEM : 089887
Reference ADEPEM : 056074
Module electronique edw150*
Reference ADEPEM : 128574
Resistance 1800w , 49025127
Reference ADEPEM : 157271
Pressostat analogique 1174745107
Type: PressostatsA.e.g, Electrolux, Progress
Reference ADEPEM : 154698
Bras de lavage inferieur
Type: Bras de lavageA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 073660
Bras de lavage superieur 8073821061
Type: Bras de lavageProgress, Electrolux, Ikea
Reference ADEPEM : 212712
Reference ADEPEM : 095475
Element de pulverisation inferieur
Type: Bras de lavageA.e.g, Electrolux, Zanussi
Reference ADEPEM : 197555
Reference ADEPEM : 049750
Joint de cuvette 5065923100/0
Reference ADEPEM : 058594
Joint torique de cuve
Reference ADEPEM : 130449
Module d'affichage edw1510
Type: ModulesElectrolux, A.e.g, Progress
Reference ADEPEM : 144465
Module de commande edw1100* 1113310526
Reference ADEPEM : 124098
Trappe produit de rinçage
Reference ADEPEM : 182165
Traverse avant
Reference ADEPEM : 091622
Reference ADEPEM : 089895
Pressostat 140000554083
Reference ADEPEM : 156588
Panier a couverts 1525593008
Reference ADEPEM : 074931
Panier inferieur 140133729099
Type: Bacs et paniersElectrolux, Faure, Zanussi
Reference ADEPEM : 125269
Reference ADEPEM : 075295
Serrure loquet 4055283925
Reference ADEPEM : 068949
Module de puissance 140059122220*
Reference ADEPEM : 212314
Ressort de porte l=278
Type: Amortisseurs et ressortsArthur martin, A.e.g, Zanussi
Reference ADEPEM : 132473
Durite bac pompe cyclage 1118455102
Type: Tuyaux et duritesA.e.g, Arthur martin, Faure
Reference ADEPEM : 073472
Griffes caoutchouc 8074683056
Type: DiversProgress, Electrolux, Ikea
Reference ADEPEM : 205059
Roulette panier inferieur par 8
Reference ADEPEM : 057118
Roulettes de rail par 4, 50299970009
Reference ADEPEM : 182150
Tuyau aquastop 5029566300/4
Reference ADEPEM : 065032
Type: Distributeurs lessiveElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 152565
Reference ADEPEM : 120160
Filtre de cuve, 1119161105
Type: FiltresA.e.g, Electrolux, Progress
Reference ADEPEM : 110143
Filtre d'evacuation, 8075472269
Type: FiltresElectrolux, A.e.g, Ikea
Reference ADEPEM : 181350
Grand couvercle de la boite produit
Type: Capots et couverclesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 085254
Rail de guidage de pied arriere
Type: DiversA.e.g, Electrolux, Arthur martin
Reference ADEPEM : 119966
Roulette panier par 8 50279059005
Reference ADEPEM : 055859
Couvercle liquide rincage
Reference ADEPEM : 095570
Durite produit adoucissant
Reference ADEPEM : 076356
Interrupteur 6 cosses 481941029126
Type: Interrupteurs et switchWhirlpool, Faure, Zanussi
Reference ADEPEM : 006199
Interrupteur marche - arret
Type: Interrupteurs et switchElectrolux, A.e.g, Faure
Reference ADEPEM : 159412
Joint bas de porte 14005563601/7
Type: JointsA.e.g, Electrolux, Ikea
Reference ADEPEM : 154434
Joint de conduit 152311901/2
Reference ADEPEM : 049027
Type: Bacs et paniersElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 093312
Pied reglable avant
Type: PiedsA.e.g, Electrolux, Arthur martin
Reference ADEPEM : 109199
Adoucisseur
Type: AdoucisseurA.e.g, Electrolux, Arthur martin
Reference ADEPEM : 081878
Boite a produits 14000077501/9
Type: Distributeurs lessiveA.e.g, Electrolux, Ikea
Reference ADEPEM : 129752
Bouchon de bac a sel
Type: BouchonsArthur martin, A.e.g, Electrolux
Reference ADEPEM : 080689
Bras de lavage intermediaire 8083211121
Type: Bras de lavageA.e.g, Electrolux, Ikea
Reference ADEPEM : 175589
Charnières droite + gauche 4055331799
Type: CharnieresFaure, A.e.g, Zanussi
Reference ADEPEM : 214428
Durite bac pompe de vidange
Type: Tuyaux et duritesA.e.g, Arthur martin, Zanussi
Reference ADEPEM : 073473
Durite cuve resistance
Type: Tuyaux et duritesA.e.g, Electrolux, Progress
Reference ADEPEM : 171281
Durite pompe cyclage
Reference ADEPEM : 155889
Entonnoir a sel
Type: UstensilesElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 189539
Fermeture de porte
Type: Securites et verrousA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 138554
Fermeture de porte 4055392551
Type: Securites et verrousElectrolux, A.e.g, Ikea
Reference ADEPEM : 190164
Filtre antiparasite 0.47µf
Type: CondensateursElectrolux, A.e.g, Progress
Reference ADEPEM : 184341
Guide d'air
Type: DiversElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 118907
Interrupteur 4 cosses
Type: Interrupteurs et switchSmeg, Faure, Zanussi
Reference ADEPEM : 084507
Interrupteur 6 cosses 92742816
Type: Interrupteurs et switchCandy, Rosieres, Faure
Reference ADEPEM : 026255
Interrupteur flotteur 140000565048
Type: Interrupteurs et switchElectrolux, A.e.g, Ikea
Reference ADEPEM : 190583
Module de puissance *
Reference ADEPEM : 179646
Poignee de porte blanche 152539800/2
Type: PoigneesFaure, Zanussi, Progress
Reference ADEPEM : 100108
Pompe de cyclage 14007440303/5
Type: PompesElectrolux, A.e.g, Faure
Reference ADEPEM : 209837
Pompe de cyclage 4055070025
Type: PompesFaure, Electrolux, Zanussi
Reference ADEPEM : 085810
Pompe de cyclage eb085d25/2t
Type: PompesElectrolux, A.e.g, Progress
Reference ADEPEM : 127703
Support bras superieur
Type: Bras de lavageElectrolux, A.e.g, Faure
Reference ADEPEM : 120157
Type: Bras de lavageA.e.g, Electrolux, Progress
Reference ADEPEM : 125277
Support roulettes reglable droit
Type: Supports et fixationsElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 103767
Vis de reglage pied central
Type: Visserie et emboutsA.e.g, Electrolux, Progress
Reference ADEPEM : 167785
Charniere de porte par 2
Type: CharnieresA.e.g, Faure, Electrolux
Reference ADEPEM : 122600
Cliquet porte 14003530011/4
Reference ADEPEM : 201158
Conduit d'alimentation superieur
Reference ADEPEM : 110819
Durite raccord cuve-resistance
Reference ADEPEM : 156968
Écran pare-vapeur 140073097010
Type: DiversA.e.g, Electrolux, Progress
Reference ADEPEM : 212502
Joint d'adoucisseur
Type: JointsArthur martin, Faure, A.e.g
Reference ADEPEM : 063919
Joint de tour de porte 117126545
Type: JointsElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 072305
Kit capteur de pression 4055346060
Type: Capteurs et sondesElectrolux, A.e.g, Zanussi
Reference ADEPEM : 178559
Pompe de cyclage
Type: PompesArthur martin, Electrolux, A.e.g
Reference ADEPEM : 064077
Pressostat securite 123-98 1528189127
Reference ADEPEM : 090901
Resistance 1800w + capot , 405537372/6
Reference ADEPEM : 186191
Vis de porte par 2
Type: Visserie et emboutsA.e.g, Electrolux, Zanussi
Reference ADEPEM : 121601
