Reference ADEPEM : 029992
Reference ADEPEM : 017901
Poulie tendeur 1250125034
Reference ADEPEM : 017808
Courroie 1904h7 = 1904phe
Reference ADEPEM : 038237
Condensateur 2µf 400v
Type: CondensateursMiele, Brandt, Electrolux
Reference ADEPEM : 029930
Courroie 1975h5 = 5phe1975
Reference ADEPEM : 005362
Galet de tambour 1364059004
Reference ADEPEM : 160371
Gache fermeture porte 1255114025
Type: Securites et verrousFaure, Zanussi, Arthur martin
Reference ADEPEM : 039391
Condensateur 5µf 400v
Reference ADEPEM : 029933
Condensateur 9µf 400v
Type: CondensateursElectrolux, Faure, Arthur martin
Reference ADEPEM : 029936
Courroie 1938h7 50205820009
Reference ADEPEM : 017472
Courroie 1980h7
Type: CourroiesBosch, Arthur martin, Zanussi
Reference ADEPEM : 029993
Feutre avant 1250028055
Reference ADEPEM : 005243
Reference ADEPEM : 034485
Doigt de contact
Reference ADEPEM : 035130
Pompe de vidange, 1258349214
Reference ADEPEM : 055709
Bague de serrage 1250091004
Reference ADEPEM : 005244
Condensateur 9µf
Type: CondensateursZanussi, Electrolux, Arthur martin
Reference ADEPEM : 089185
Module electronique*
Type: ModulesElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 151640
Thermostat 110°nc
Type: ThermostatsZanussi, Arthur martin, Faure
Reference ADEPEM : 017497
Condensateur 7µf
Type: CondensateursA.e.g, Electrolux, Zanussi
Reference ADEPEM : 300395
Courroie 1956j3 = 3pj1956
Reference ADEPEM : 030000
Hublot de lampe
Type: HublotsElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 088185
Condensateur 2µf 400v 1250020813
Type: CondensateursElectrolux, A.e.g, Zanussi
Reference ADEPEM : 075174
Interrupteur marche / arret
Reference ADEPEM : 053073
Sonde 3792171203
Type: Capteurs et sondesElectrolux, A.e.g, Faure
Reference ADEPEM : 107214
Crochet de hublot
Type: HublotsZanussi, Arthur martin, Faure
Reference ADEPEM : 037731
Module de commande 1256678077*
Type: ModulesElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 149377
Resistance 2200w 125753214/1
Reference ADEPEM : 111289
Thermostat 110°nc/82°nc
Type: ThermostatsZanussi, Faure, Arthur martin
Reference ADEPEM : 005364
Module de commande*
Reference ADEPEM : 140385
Reference ADEPEM : 141160
Pied reglable 1250119029
Reference ADEPEM : 017304
Resistance 1400w/1000w 125436512/3
Type: ResistancesFaure, Arthur martin, Zanussi
Reference ADEPEM : 048012
Ressort
Reference ADEPEM : 054972
Turbine arriere
Type: Ventilateurs et helicesElectrolux, Faure, Zanussi
Reference ADEPEM : 134088
Turbine ventilation moteur
Type: Ventilateurs et helicesZanussi, Electrolux, Faure
Reference ADEPEM : 041197
Palier seche-linge
Reference ADEPEM : 005245
Resistance 1630w+750w 5009793800/0
Type: ResistancesFaure, Arthur martin, Lincoln
Reference ADEPEM : 030757
Sonde de temperature 3792171021
Type: Capteurs et sondesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 051617
Courroie 1936h7 = 7ph1936
Type: CourroiesElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 111280
Condensateur 6µf 400v 1125429009
Type: CondensateursElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 075173
Feutre avant 125836800/8
Type: DiversFaure, Zanussi, Arthur martin
Reference ADEPEM : 017853
Ampoule tambour 10w e14 1256508019
Type: Lampes et ampoulesElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 091354
Antiparasite 0,47µf + cordon
Reference ADEPEM : 124795
Axe de tambour seche-linge
Type: Cuves et tamboursFaure, Electrolux, Arthur martin
Reference ADEPEM : 005250
Bouchon de sortie d'air
Type: BouchonsZanussi, Faure, Arthur martin
Reference ADEPEM : 055196
Bride
Type: DiversElectrolux, Zanussi, Arthur martin
Reference ADEPEM : 063623
Charbon 6x6x19 (par 1)
Type: Charbons moteurA.e.g, Electrolux, Faure
Reference ADEPEM : 051080
Feutre avant
Type: DiversElectrolux, Zanussi, Faure
Reference ADEPEM : 051079
Filtre tamis seche linge
Reference ADEPEM : 062855
Module de commande*
Reference ADEPEM : 142740
Reference ADEPEM : 111223
Support moteur
Type: MoteursZanussi, Faure, Arthur martin
Reference ADEPEM : 005237
Thermostat
Reference ADEPEM : 053334
Bouton programmateur blanc
Type: BoutonsElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 095061
Condensateur 4µf, 400v, 1256418011
Reference ADEPEM : 051443
Condenseur
Type: CondenseurElectrolux, Faure, Arthur martin
Reference ADEPEM : 056603
Etrier support moteur avant
Reference ADEPEM : 155179
Feutre avant
Reference ADEPEM : 127044
Filtre inferieur
Type: FiltresZanussi, Faure, Arthur martin
Reference ADEPEM : 084164
Filtre superieur
Reference ADEPEM : 084163
Interrupteur marche arret
Type: Interrupteurs et switchZanussi, Faure, Electrolux
Reference ADEPEM : 062998
Joint avant tambour
Reference ADEPEM : 090234
Joint de feutre arriere
Type: JointsZanussi, Faure, Electrolux
Reference ADEPEM : 077033
Joint de porte
Reference ADEPEM : 063490
Module de commande*
Reference ADEPEM : 156951
Module de commande*
Reference ADEPEM : 142171
Poignee hublot blanche 1242060000
Type: PoigneesArthur martin, Faure, Electrolux
Reference ADEPEM : 005113
Poignee hublot blanche 5009943400/8
Reference ADEPEM : 017332
Porte interieure
Reference ADEPEM : 061594
Resistance seche-linge 1000w/1400w
Type: ResistancesElectrolux, Arthur martin, Faure
Reference ADEPEM : 104396
Resistance seche-linge 1400w+600w
Type: ResistancesArthur martin, Faure, Zanussi
Reference ADEPEM : 089047
Ressort tendeur
Reference ADEPEM : 005238
Rondelle poulie
Reference ADEPEM : 040923
Aube de tambour
Type: Aubes de tambourArthur martin, Electrolux, Faure
Reference ADEPEM : 134074
Bouchon
Type: BouchonsElectrolux, A.e.g, Zanussi
Reference ADEPEM : 089444
Couvercle tamis de porte
Reference ADEPEM : 175390
Doigt de verrou
Type: Securites et verrousZanussi, Faure, Arthur martin
Reference ADEPEM : 035127
Douille support roulette
Reference ADEPEM : 105833
Feutre adhesif
Type: DiversElectrolux, Faure, Zanussi
Reference ADEPEM : 097770
Feutre avant
Type: DiversArthur martin, Electrolux, Faure
Reference ADEPEM : 017328
Filtre a peluches,1254242306, 1254242207
Type: FiltresElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 101490
Filtre a peluches inferieur
Type: FiltresFaure, Arthur martin, Zanussi
Reference ADEPEM : 062856
Gache
Type: Securites et verrousZanussi, Arthur martin, Faure
Reference ADEPEM : 093237
Hublot de lampe 1123424002
Type: HublotsA.e.g, Electrolux, Zanussi
Reference ADEPEM : 142920
Joint couvercle panneau arrière
Reference ADEPEM : 133314
Reference ADEPEM : 133315
Type: JointsFaure, Arthur martin, Electrolux
Reference ADEPEM : 133316
Joint de condenseur
Reference ADEPEM : 073680
Joint de contre-porte
Type: JointsZanussi, Electrolux, Faure
Reference ADEPEM : 142342
Joint hublot 1250295001
Type: JointsZanussi, Faure, Arthur martin
Reference ADEPEM : 043636
Module de commande*
Type: ModulesArthur martin, Electrolux
Reference ADEPEM : 170399
Module de commande*
Type: ModulesElectrolux, Faure, Proline
Reference ADEPEM : 142326
Module electronique configure
Reference ADEPEM : 088123
Moteur seche linge 20583080
Type: MoteursElectrolux, A.e.g, Zanussi
Reference ADEPEM : 118410
Plinthe droite condenseur
Type: DiversZanussi, Faure, Electrolux
Reference ADEPEM : 109971
Poulie moteur
Type: Pignons et pouliesElectrolux, Zanussi, A.e.g
Reference ADEPEM : 126454
Reservoir eau
Type: ReservoirsElectrolux, Zanussi, Faure
Reference ADEPEM : 071858
Resistance 1400w+1000w
Reference ADEPEM : 040709
Resistance seche-linge 2x1200w
Reference ADEPEM : 030763
Ressort crochet 124013903/8
Type: Amortisseurs et ressortsArthur martin, Electrolux, Zanussi
Reference ADEPEM : 005041
Type: Securites et verrousElectrolux, Zanussi, Faure
Reference ADEPEM : 134073
Trappe inferieure droite
Type: Capots et couverclesFaure, Arthur martin, Privileg
Reference ADEPEM : 155634
Vis moteur 1240222016
Reference ADEPEM : 212420
