Reference ADEPEM : 108321
Résistance + thermostats 481231028307
Reference ADEPEM : 013191
Reference ADEPEM : 005886
Reference ADEPEM : 035505
Ampoule 15w e14 300°
Reference ADEPEM : 023507
Gache de porte 481227138462
Type: Securites et verrousBauknecht, Whirlpool, Laden
Reference ADEPEM : 043476
Reference ADEPEM : 029994
Courroie 1936h6 = 6phe1936
Reference ADEPEM : 048802
Ampoule 15w e14
Type: Lampes et ampoulesWhirlpool, Bosch, Liebherr
Reference ADEPEM : 011103
Pompe vidange b13-6ab03151 481070109852
Reference ADEPEM : 141387
Reference ADEPEM : 017901
Pompe de vidange c00306876
Type: PompesBauknecht, Whirlpool, Indesit
Reference ADEPEM : 065522
Courroie 1992h7 = 7ph1992
Type: CourroiesBosch, Whirlpool, Bauknecht
Reference ADEPEM : 175008
Filtre en mousse 220x100mm 481010354757
Type: FiltresWhirlpool, Bauknecht, Ignis
Reference ADEPEM : 116428
Poulie tendeur 1250125034
Reference ADEPEM : 017808
Filtre seche-linge 481010615876
Type: FiltresWhirlpool, Bauknecht, Indesit
Reference ADEPEM : 171596
Filtre triangulaire, 481010345281
Reference ADEPEM : 141599
Sonde ctn 481228219485
Reference ADEPEM : 069141
Filtre tamis seche-linge 481248058322
Reference ADEPEM : 035864
Reference ADEPEM : 046158
Condensateur 12,5µf 400v
Reference ADEPEM : 029938
Roulette de tambour, 481010456115
Type: Roues et roulettesWhirlpool, Bauknecht, Laden
Reference ADEPEM : 172506
Gache de porte 481227138354
Reference ADEPEM : 013211
Courroie 1965h8
Reference ADEPEM : 029990
Reference ADEPEM : 048857
Turbine de ventilation c00738545
Type: Ventilateurs et helicesWhirlpool, Bauknecht, Ignis
Reference ADEPEM : 128266
Reference ADEPEM : 015668
Aube de tambour 481941849713
Reference ADEPEM : 014776
Joint de porte 481010713648
Reference ADEPEM : 111396
Reference ADEPEM : 036472
Resistance 2200w 481231018627
Type: ResistancesBauknecht, Whirlpool
Reference ADEPEM : 037117
Reference ADEPEM : 048543
Bouton de commande 481071425591
Type: BoutonsBauknecht, Laden, Ignis
Reference ADEPEM : 113355
Microswitch 3 cosses 16a
Reference ADEPEM : 030961
Hublot de lampe 74x2387
Type: HublotsCandy, Brandt, Sauter
Reference ADEPEM : 045054
Reference ADEPEM : 036473
Resistance 1300w x2 481225928895
Type: ResistancesBauknecht, Whirlpool, Ignis
Reference ADEPEM : 070173
Poulie tendeur 484000008521
Reference ADEPEM : 108322
Bague star turbine
Reference ADEPEM : 064493
Courroie 1985h9
Type: CourroiesBauknecht, Ocean
Reference ADEPEM : 029991
Resistance 2400w 481010669313
Reference ADEPEM : 121831
Doigt de securite de porte 480112101518
Type: Securites et verrousWhirlpool, Laden, Bauknecht
Reference ADEPEM : 107692
Joint sortie pompe vidange 481953058026
Type: JointsWhirlpool, Laden, Radiola
Reference ADEPEM : 031819
Module de controle 480112101535*
Reference ADEPEM : 127543
Reference ADEPEM : 018560
Courroie 57x1048
Type: CourroiesThomson, Brandt, Vedette
Reference ADEPEM : 016009
Doigt de verrou de porte
Reference ADEPEM : 114254
Palier gauche 481952028026
Type: Roulements et paliersWhirlpool, Laden, Radiola
Reference ADEPEM : 030917
Courroie 1936h8 57x0273
Type: CourroiesWhirlpool, Laden, Bauknecht
Reference ADEPEM : 019848
Courroie 1985h7
Type: CourroiesBauknecht, Francia, Ocean
Reference ADEPEM : 050597
Palier droit 481941818204
Reference ADEPEM : 015670
Ampoule led 1w, e14, 230v, t25, lrf200
Type: Lampes et ampoulesWhirlpool, Indesit, Bauknecht
Reference ADEPEM : 121068
Courroie 1310j5
Type: CourroiesWhirlpool, Laden, Ignis
Reference ADEPEM : 037178
Courroie 1992h6 = 6ph1992
Type: CourroiesSiemens, Bosch, Bauknecht
Reference ADEPEM : 029989
Reference ADEPEM : 013544
Module de commande*
Reference ADEPEM : 161595
Resistance seche-linge 2x1000w
Reference ADEPEM : 091618
Thermostat k59s2788 = a130681r
Type: ThermostatsWhirlpool, Bauknecht, Laden
Reference ADEPEM : 056438
Joint bac a eau
Reference ADEPEM : 096023
Joint torique
Reference ADEPEM : 061202
Microswitch 3 cosses securite de pompe
Reference ADEPEM : 063798
Resistance 2050w 481225928679
Reference ADEPEM : 036803
Resistance 950w+950w 481225928928
Type: ResistancesWhirlpool, Laden, Bauknecht
Reference ADEPEM : 086120
Ecrou de turbine
Reference ADEPEM : 183280
Type: FiltresThomson, Brandt, Vedette
Reference ADEPEM : 016001
Microswitch 2 cosses depart/securite
Reference ADEPEM : 013225
Module de commande*
Reference ADEPEM : 165167
Module de commande*
Reference ADEPEM : 142202
Poulie tendeur 481010700903
Reference ADEPEM : 143952
Touches option
Reference ADEPEM : 115898
Galet tambour
Reference ADEPEM : 038016
Bouton programmateur 481241458316
Type: BoutonsLaden, Ignis, Bauknecht
Reference ADEPEM : 086917
Pied
Reference ADEPEM : 103431
Turbine avant
Type: Ventilateurs et helicesWhirlpool, Bauknecht, Laden
Reference ADEPEM : 068621
Tuyau socle/bec verseur 480112101508
Reference ADEPEM : 147001
Bac recuperateur
Type: Bacs et paniersWhirlpool, Proline, Laden
Reference ADEPEM : 098487
Condensateur 8µf 450v
Reference ADEPEM : 113548
Doigt de verrouillage 481227618422
Reference ADEPEM : 013227
Interrupteur 481227618278
Reference ADEPEM : 061566
Joint de porte 481246668607
Reference ADEPEM : 043328
Joint tambour avant 481246668561
Reference ADEPEM : 041709
Portillon condenseur c00850082
Type: PortesWhirlpool, Bauknecht, Laden
Reference ADEPEM : 192652
Sonde d'humidite filtre
Type: Capteurs et sondesBauknecht, Whirlpool, Laden
Reference ADEPEM : 054280
Antiparasite 0,1µf
Reference ADEPEM : 108455
Antiparasite 1,2µf + 2x10000pf
Type: CondensateursWhirlpool, Laden, Radiola
Reference ADEPEM : 014717
Dectecteur de niveau d'eau
Type: Boitiers et cartersWhirlpool, Bauknecht, Laden
Reference ADEPEM : 177034
Durite cuve/pompe
Type: Tuyaux et duritesWhirlpool, Laden, Ignis
Reference ADEPEM : 030412
Feutre seche-linge
Reference ADEPEM : 019854
Filtre tamis 481010423761
Reference ADEPEM : 115981
Thermostat a130778-33
Reference ADEPEM : 137587
Verrou de porte
Reference ADEPEM : 195280
Aube de tambour
Type: Aubes de tambourWhirlpool, Bauknecht, Laden
Reference ADEPEM : 075618
Axe avant + galet
Type: DiversWhirlpool, Bauknecht, Laden
Reference ADEPEM : 069890
Axe court arriere galet
Reference ADEPEM : 071127
Condenseur
Type: CondenseurWhirlpool, Bauknecht, Laden
Reference ADEPEM : 064223
Lamelle de contact 51x8184
Type: DiversBrandt, Vedette, Fagor
Reference ADEPEM : 044113
Pompe de vidange 481936018203
Type: PompesWhirlpool, Laden, Radiola
Reference ADEPEM : 014249
Sonde humidite 480112101486
Reference ADEPEM : 177033
Verrou de porte 480112101507
Reference ADEPEM : 111778
Module d'humidite 481223958063
Reference ADEPEM : 105043
Resistance 1900w 481231018585
Reference ADEPEM : 047442
Resistance 2700w 481010573611
Reference ADEPEM : 162306
