Reference ADEPEM : 108321
Reference ADEPEM : 029992
Reference ADEPEM : 029994
Courroie 1930h7 8996470700601
Type: CourroiesBosch, Siemens, Candy
Reference ADEPEM : 052743
Courroie 1930h6 = 6phe1930
Reference ADEPEM : 028368
Poulie tendeur 1250125034
Reference ADEPEM : 017808
Courroie 1904h7 = 1904phe
Reference ADEPEM : 038237
Charniere de hublot
Type: CharnieresFar, Curtiss, Bosch
Reference ADEPEM : 034919
Poulie
Type: Pignons et pouliesBellavita, Curtiss, Oceanic
Reference ADEPEM : 180764
Courroie 1975h5 = 5phe1975
Reference ADEPEM : 005362
Galet de tambour 1364059004
Reference ADEPEM : 160371
Charniere de hublot
Type: CharnieresContinental edison, Bellavita, Proline
Reference ADEPEM : 162455
Courroie 1810j3 481935818131
Reference ADEPEM : 040007
Condensateur 7,5µf 420v-450v c00095649
Type: CondensateursCandy, Rosieres, Bellavita
Reference ADEPEM : 073041
Charniere de porte hublot , 481941719341
Type: CharnieresFar, Selecline, Whirlpool
Reference ADEPEM : 014698
Condensateur 11µf/450v
Type: CondensateursBellavita, Highone
Reference ADEPEM : 051697
Resistance 2500w 32x4829
Reference ADEPEM : 030791
Résistance sole 1600w, 524012200
Type: ResistancesFar, Laco, Horn
Reference ADEPEM : 044036
Courroie 1810h8/1825h8
Type: CourroiesCurtiss, Far, Funix
Reference ADEPEM : 043051
Microswitch 3 cosses 1505019008
Type: Interrupteurs et switchBosch, Siemens, Arthur martin
Reference ADEPEM : 030964
Fusible 15a 5x20 t ceramique
Type: FusiblesBellavita, California, Funix
Reference ADEPEM : 094586
Pompe de relevage
Type: PompesBeko, Grundig, Saba
Reference ADEPEM : 108131
Resistance 2200w 125753214/1
Reference ADEPEM : 111289
Turbine arriere
Type: Ventilateurs et helicesElectrolux, Faure, Zanussi
Reference ADEPEM : 134088
Palier seche-linge
Reference ADEPEM : 005245
Renfort de charniere de porte
Type: CharnieresElectrolux, Zanussi, A.e.g
Reference ADEPEM : 152188
Resistance 1600w-900w, 32031612
Type: ResistancesBellavita
Reference ADEPEM : 213911
Condensateur 8µf 450v
Reference ADEPEM : 113548
Feutre avant
Type: DiversCalifornia, Bellavita, Bluesky
Reference ADEPEM : 100242
Filtre tamis seche linge
Reference ADEPEM : 062855
Patin feutre avant
Type: PiedsBellavita, California, Funix
Reference ADEPEM : 145308
Poulie tendeur
Type: Pignons et pouliesAya, Bellavita, Highone
Reference ADEPEM : 118623
Bouchon de reservoir condenseur
Type: BouchonsZanussi, Electrolux, Faure
Reference ADEPEM : 085945
Charniere de hublot 87025
Type: CharnieresBellavita, California, Saba
Reference ADEPEM : 197582
Courroie 1950h7
Type: CourroiesBellavita, Curtiss, Jeken
Reference ADEPEM : 180763
Feutre avant
Type: DiversElectrolux, Zanussi, Faure
Reference ADEPEM : 127044
Feutre seche-linge avant
Type: DiversBellavita
Reference ADEPEM : 201554
Type: FiltresContinental edison, Bellavita, California
Reference ADEPEM : 134982
Joint avant tambour
Reference ADEPEM : 090234
Joint de hublot
Type: JointsFar, Curtiss, Selecline
Reference ADEPEM : 051144
Joint de panneau arriere
Reference ADEPEM : 133067
Joint de porte
Reference ADEPEM : 063490
Minuterie t600
Type: Minuteurs et programmateursFar, Aya, Bellavita
Reference ADEPEM : 121504
Porte interieure
Reference ADEPEM : 061594
Poulie seche-linge
Type: Pignons et pouliesElectrolux, Faure, Arthur martin
Reference ADEPEM : 018674
Poulie tendeur
Reference ADEPEM : 140723
Reservoir seche-linge
Type: ReservoirsBellavita
Reference ADEPEM : 156138
Type: Securites et verrousCurtiss, Far, Horn
Reference ADEPEM : 051192
Switch de recuperateur d'eau
Type: Interrupteurs et switchCurtiss, Far, Bellavita
Reference ADEPEM : 092856
Thermostat 60°nc rearmable
Type: ThermostatsFar, Bluesky, Franger
Reference ADEPEM : 072004
Thermostat ksd303
Type: ThermostatsBellavita
Reference ADEPEM : 130247
Thermostat securite rearmable
Type: ThermostatsCurtiss, Far, Selecline
Reference ADEPEM : 049625
Turbine ventilation
Type: Ventilateurs et helicesCurtiss, Far, Selecline
Reference ADEPEM : 056670
Amortisseur caoutchouc avant moteur
Type: Amortisseurs et ressortsElectrolux, A.e.g, Zanussi
Reference ADEPEM : 113917
Axe de bouton programmateur
Type: BoutonsCurtiss, Funix, Selecline
Reference ADEPEM : 180943
Bornier 125422714/1
Type: ConnectiquesElectrolux, Zanussi, Faure
Reference ADEPEM : 116127
Bouchon
Type: BouchonsElectrolux, A.e.g, Zanussi
Reference ADEPEM : 089444
Capot de ventilation
Type: Capots et couverclesCurtiss, Far, Selecline
Reference ADEPEM : 091999
Charniere de porte
Type: CharnieresElectrolux, A.e.g, Zanussi
Reference ADEPEM : 082595
Condenseur
Type: CondenseurElectrolux, A.e.g, Zanussi
Reference ADEPEM : 091459
Douille support roulette
Reference ADEPEM : 105833
Etrier support arriere moteur
Reference ADEPEM : 113924
Feutre avant
Type: DiversCurtiss, Bellavita, Funix
Reference ADEPEM : 147611
Filtre a peluches,1254242306, 1254242207
Type: FiltresElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 101490
Filtre tamis a peluches
Type: FiltresCalifornia, Bellavita, Funix
Reference ADEPEM : 171842
Joint bride reservoir 13x10x2
Type: JointsFaure, Zanussi, Electrolux
Reference ADEPEM : 172076
Joint de condenseur
Reference ADEPEM : 073680
Joint de condenseur avant
Reference ADEPEM : 143967
Porte interieure + joint
Type: PortesBellavita, Curtiss, Selecline
Reference ADEPEM : 165211
Programmateur ec4818.02
Type: Minuteurs et programmateursCurtiss, Far, Bellavita
Reference ADEPEM : 057737
Reservoir eau
Type: ReservoirsElectrolux, Zanussi, Faure
Reference ADEPEM : 071858
Resistance seche-linge 1800w
Type: ResistancesPhilips, California, Bauknecht
Reference ADEPEM : 111744
Type: Securites et verrousElectrolux, Zanussi, Faure
Reference ADEPEM : 134073
Thermostat 65° rearmable
Reference ADEPEM : 130248
Thermostat entree
Reference ADEPEM : 072160
Turbine ventilateur
Reference ADEPEM : 048445
Charbon par 1 , 5x8x19
Type: Charbons moteurCurtiss, Far, Funix
Reference ADEPEM : 119447
Interrupteur 2 cosses marche - arret
Type: Interrupteurs et switchBellavita, Far, Essentiel b
Reference ADEPEM : 146789
Cordon alimentation
Type: Cables et cordonsElectrolux, A.e.g, Zanussi
Reference ADEPEM : 092555
Douille arriere moteur
Reference ADEPEM : 113918
Poulie tendeur
Reference ADEPEM : 207800
Courroie 2010h7, 42164399, 42232588
Type: CourroiesBellavita, Oceanic, Saba
Reference ADEPEM : 211924
Joint arriere avec feutre
Reference ADEPEM : 043004
Pompe de relevage
Type: PompesBellavita, Far
Reference ADEPEM : 213919
Tuyau d'evacuation
Type: Tuyaux et duritesFar, Curtiss, Franger
Reference ADEPEM : 043853
Gache de porte + crochet
Type: Securites et verrousCurtiss, Bellavita, Urania
Reference ADEPEM : 089468
Relais de liaison de securite
Type: Relais et klixonsAya, Bellavita, Curtiss
Reference ADEPEM : 159199
Type: ResistancesCurtiss, Bellavita, Far
Reference ADEPEM : 068722
Tuyau evacuation seche-linge
Type: Tuyaux et duritesFar, Curtiss, Laden
Reference ADEPEM : 015726
