Condensateur 7µf c00279233
Reference ADEPEM : 114797
Reference ADEPEM : 029992
Ampoule 15w e14 300°
Reference ADEPEM : 023507
Reference ADEPEM : 029994
Courroie 1930h7 8996470700601
Type: CourroiesBosch, Siemens, Candy
Reference ADEPEM : 052743
Courroie 1930h6 = 6phe1930
Reference ADEPEM : 028368
Reference ADEPEM : 017901
Poulie tendeur 1250125034
Reference ADEPEM : 017808
Courroie 1971h7, 140056254018
Reference ADEPEM : 144216
Resistance 1900w + 700w 1366110011
Type: ResistancesA.e.g, Electrolux, Faure
Reference ADEPEM : 132274
Courroie 1904h7 = 1904phe
Reference ADEPEM : 038237
Module de puissance 1366100301*
Reference ADEPEM : 160942
Condensateur 2µf 400v
Type: CondensateursMiele, Brandt, Electrolux
Reference ADEPEM : 029930
Doigt de verrou 8086811141
Type: Securites et verrousElectrolux, Faure, A.e.g
Reference ADEPEM : 170357
Galet de tambour 1364059004
Reference ADEPEM : 160371
Charniere de porte 1366253233
Type: CharnieresElectrolux, A.e.g
Reference ADEPEM : 182972
Condensateur 5µf 400v
Reference ADEPEM : 029933
Filtre tamis seche-linge, 1366019014
Type: FiltresA.e.g, Electrolux, Zanussi
Reference ADEPEM : 141898
Condensateur 12µf 400v
Type: CondensateursElectrolux, A.e.g
Reference ADEPEM : 181935
Condensateur 9µf 400v
Type: CondensateursElectrolux, Faure, Arthur martin
Reference ADEPEM : 029936
Fusible thermique 167°= 169°
Type: FusiblesA.e.g, Seb, Electrolux
Reference ADEPEM : 030661
Courroie 1938h7 50205820009
Reference ADEPEM : 017472
Courroie 1980h7
Type: CourroiesBosch, Arthur martin, Zanussi
Reference ADEPEM : 029993
Feutre avant 1250028055
Reference ADEPEM : 005243
Reference ADEPEM : 034485
Doigt de contact
Reference ADEPEM : 035130
Pompe de vidange, 1258349214
Reference ADEPEM : 055709
Bague de serrage 1250091004
Reference ADEPEM : 005244
Condensateur 9µf
Type: CondensateursZanussi, Electrolux, Arthur martin
Reference ADEPEM : 089185
Module electronique*
Type: ModulesElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 151640
Thermostat 110°nc
Type: ThermostatsZanussi, Arthur martin, Faure
Reference ADEPEM : 017497
Condensateur 7µf
Type: CondensateursA.e.g, Electrolux, Zanussi
Reference ADEPEM : 300395
Hublot de lampe
Type: HublotsElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 088185
Courroie 1951h5
Type: CourroiesElectrolux, Candy
Reference ADEPEM : 048810
Voyant
Type: Lampes et ampoulesSmeg, Gaggenau, Faure
Reference ADEPEM : 027908
Condensateur 2µf 400v 1250020813
Type: CondensateursElectrolux, A.e.g, Zanussi
Reference ADEPEM : 075174
Interrupteur marche / arret
Reference ADEPEM : 053073
Sonde 3792171203
Type: Capteurs et sondesElectrolux, A.e.g, Faure
Reference ADEPEM : 107214
Thermostat 150°
Type: ThermostatsA.e.g, Electrolux, Blomberg
Reference ADEPEM : 022198
Crochet de hublot
Type: HublotsZanussi, Arthur martin, Faure
Reference ADEPEM : 037731
Module de commande 1256678077*
Type: ModulesElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 149377
Resistance 2200w 125753214/1
Reference ADEPEM : 111289
Thermostat 110°nc/82°nc
Type: ThermostatsZanussi, Faure, Arthur martin
Reference ADEPEM : 005364
Module de commande*
Reference ADEPEM : 140385
Module de puissance 14012689524/6*
Type: ModulesElectrolux, Faure
Reference ADEPEM : 203679
Reference ADEPEM : 141160
Panneau arriere
Type: Capots et couverclesElectrolux
Reference ADEPEM : 169478
Pied reglable 1250119029
Reference ADEPEM : 017304
Resistance 1400w/1000w 125436512/3
Type: ResistancesFaure, Arthur martin, Zanussi
Reference ADEPEM : 048012
Resistance 1850w 150602482/5
Reference ADEPEM : 062606
Ressort
Reference ADEPEM : 054972
Turbine arriere
Type: Ventilateurs et helicesElectrolux, Faure, Zanussi
Reference ADEPEM : 134088
Turbine ventilateur avant
Type: Ventilateurs et helicesA.e.g, Electrolux, Blomberg
Reference ADEPEM : 022239
Turbine ventilation moteur
Type: Ventilateurs et helicesZanussi, Electrolux, Faure
Reference ADEPEM : 041197
Courroie 1975h5 = 5phe1975
Reference ADEPEM : 005362
Capot + resistance 2040w 481010518499
Type: ResistancesWhirlpool, Bauknecht, Ignis
Reference ADEPEM : 077361
Palier seche-linge
Reference ADEPEM : 005245
Poignee de porte, 4055237731
Type: PoigneesElectrolux, A.e.g
Reference ADEPEM : 172834
Resistance 1630w+750w 5009793800/0
Type: ResistancesFaure, Arthur martin, Lincoln
Reference ADEPEM : 030757
Sonde de temperature 3792171021
Type: Capteurs et sondesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 051617
Courroie 1936h7 = 7ph1936
Type: CourroiesElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 111280
Filtre a peluches, 8074539019
Type: FiltresElectrolux, Faure, A.e.g
Reference ADEPEM : 193120
Cable d'alimentation+antiparasite 0,27µf
Type: Cables et cordonsZanussi, Electrolux, Faure
Reference ADEPEM : 155893
Condensateur 6µf 400v 1125429009
Type: CondensateursElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 075173
Antiparasite 0,47µf + cordon
Reference ADEPEM : 124795
Charbon 6x6x19 (par 1)
Type: Charbons moteurA.e.g, Electrolux, Faure
Reference ADEPEM : 051080
Doigt de verrou
Type: Securites et verrousElectrolux, A.e.g, Faure
Reference ADEPEM : 188040
Feutre avant
Type: DiversElectrolux, Zanussi, Faure
Reference ADEPEM : 051079
Filtre tamis seche linge
Reference ADEPEM : 062855
Joint de tambour 140066097019
Type: JointsElectrolux, A.e.g
Reference ADEPEM : 199822
Module de commande*
Type: ModulesElectrolux, Rex
Reference ADEPEM : 144295
Thermostat
Reference ADEPEM : 053334
Axe de tambour seche-linge
Type: Cuves et tamboursFaure, Electrolux, Arthur martin
Reference ADEPEM : 005250
Condensateur 4µf, 400v, 1256418011
Reference ADEPEM : 051443
Doigt de verrou
Type: Securites et verrousA.e.g, Electrolux
Reference ADEPEM : 156112
Etrier support moteur avant
Reference ADEPEM : 155179
Feutre avant
Reference ADEPEM : 127044
Filtre inferieur
Type: FiltresZanussi, Faure, Arthur martin
Reference ADEPEM : 084164
Filtre superieur
Reference ADEPEM : 084163
Interrupteur de porte
Type: Interrupteurs et switchElectrolux, A.e.g, Faure
Reference ADEPEM : 179820
Interrupteur marche arret
Type: Interrupteurs et switchZanussi, Faure, Electrolux
Reference ADEPEM : 062998
Joint avant tambour
Reference ADEPEM : 090234
Joint de feutre arriere
Type: JointsZanussi, Faure, Electrolux
Reference ADEPEM : 077033
Joint de porte
Reference ADEPEM : 063490
Joint de tambour
Type: DiversElectrolux, Faure, A.e.g
Reference ADEPEM : 174054
Module de puissance*
Reference ADEPEM : 189543
Module de puissance 973916098244015
Reference ADEPEM : 300118
Moteur seche linge
Type: MoteursElectrolux, Faure
Reference ADEPEM : 184457
Moteur ventilateur
Reference ADEPEM : 099242
Poignee hublot blanche 1242060000
Type: PoigneesArthur martin, Faure, Electrolux
Reference ADEPEM : 005113
Porte interieure
Reference ADEPEM : 061594
Ressort tendeur
Reference ADEPEM : 005238
Rondelle poulie
Reference ADEPEM : 040923
Verrou de porte
Type: Securites et verrousElectrolux, Faure, Zanussi
Reference ADEPEM : 170356
Couvercle tamis de porte
Reference ADEPEM : 175390
Feutre avant
Type: DiversArthur martin, Electrolux, Faure
Reference ADEPEM : 017328
Filtre a peluches,1254242306, 1254242207
Type: FiltresElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 101490
Hublot de lampe 1123424002
Type: HublotsA.e.g, Electrolux, Zanussi
Reference ADEPEM : 142920
Joint de condenseur
Reference ADEPEM : 073680
Moteur seche linge 20583080
Type: MoteursElectrolux, A.e.g, Zanussi
Reference ADEPEM : 118410
Panneau avant + charniere 4055306585
Type: Capots et couverclesElectrolux, A.e.g
Reference ADEPEM : 169965
Poulie tendeur 1506244001
Reference ADEPEM : 040925
Resistance seche-linge 2x1200w
Type: ResistancesArthur martin, Faure, Zanussi
Reference ADEPEM : 030763
Ressort crochet 124013903/8
Type: Amortisseurs et ressortsArthur martin, Electrolux, Zanussi
Reference ADEPEM : 005041
Tambour
Type: Cuves et tamboursElectrolux, Faure, Zanussi
Reference ADEPEM : 177104
Turbine ventilateur arriere
Reference ADEPEM : 022240
Vis moteur 1240222016
Reference ADEPEM : 212420
