Condensateur 7µf c00279233
Reference ADEPEM : 114797
Reference ADEPEM : 029992
Ampoule 15w e14 300°
Reference ADEPEM : 023507
Ampoule four 25w e14 300°
Reference ADEPEM : 023508
Reference ADEPEM : 017901
Poulie tendeur 1250125034
Reference ADEPEM : 017808
Resistance 1900w + 700w 1366110011
Type: ResistancesA.e.g, Electrolux, Faure
Reference ADEPEM : 132274
Courroie 1904h7 = 1904phe
Reference ADEPEM : 038237
Module de puissance 1366100301*
Reference ADEPEM : 160942
Hublot de lampe 481245028007, 76x3143
Type: HublotsWhirlpool, Bauknecht, Brandt
Reference ADEPEM : 024648
Condensateur 2µf 400v
Type: CondensateursMiele, Brandt, Electrolux
Reference ADEPEM : 029930
Doigt de verrou 8086811141
Type: Securites et verrousElectrolux, Faure, A.e.g
Reference ADEPEM : 170357
Courroie 1975h5 = 5phe1975
Reference ADEPEM : 005362
Galet de tambour 1364059004
Reference ADEPEM : 160371
Gache fermeture porte 1255114025
Type: Securites et verrousFaure, Zanussi, Arthur martin
Reference ADEPEM : 039391
Condensateur 5µf 400v
Reference ADEPEM : 029933
Filtre tamis seche-linge, 1366019014
Type: FiltresA.e.g, Electrolux, Zanussi
Reference ADEPEM : 141898
Condensateur 9µf 400v
Type: CondensateursElectrolux, Faure, Arthur martin
Reference ADEPEM : 029936
Capot + resistance 2040w 481010518499
Type: ResistancesWhirlpool, Bauknecht, Ignis
Reference ADEPEM : 077361
Courroie 1938h7 50205820009
Reference ADEPEM : 017472
Feutre avant 1250028055
Reference ADEPEM : 005243
Reference ADEPEM : 034485
Moteur chaleur tournante 74x1146
Type: MoteursBrandt, De dietrich, Sauter
Reference ADEPEM : 047345
Doigt de contact
Reference ADEPEM : 035130
Pompe de vidange, 1258349214
Reference ADEPEM : 055709
Resistance sole 1200w, 77x3282
Type: ResistancesBrandt, Sauter, Essentiel b
Reference ADEPEM : 042169
Bague de serrage 1250091004
Reference ADEPEM : 005244
Condensateur 9µf
Type: CondensateursZanussi, Electrolux, Arthur martin
Reference ADEPEM : 089185
Thermostat 110°nc
Type: ThermostatsZanussi, Arthur martin, Faure
Reference ADEPEM : 017497
Condensateur 7µf
Type: CondensateursA.e.g, Electrolux, Zanussi
Reference ADEPEM : 300395
Courroie 1956j3 = 3pj1956
Reference ADEPEM : 030000
Voyant
Type: Lampes et ampoulesSmeg, Gaggenau, Faure
Reference ADEPEM : 027908
Condensateur 2µf 400v 1250020813
Type: CondensateursElectrolux, A.e.g, Zanussi
Reference ADEPEM : 075174
Interrupteur marche / arret
Reference ADEPEM : 053073
Sonde 3792171203
Type: Capteurs et sondesElectrolux, A.e.g, Faure
Reference ADEPEM : 107214
Crochet de hublot
Type: HublotsZanussi, Arthur martin, Faure
Reference ADEPEM : 037731
Module de commande*
Type: ModulesFaure, Zanussi
Reference ADEPEM : 139930
Resistance 2200w 125753214/1
Reference ADEPEM : 111289
Thermostat 110°nc/82°nc
Type: ThermostatsZanussi, Faure, Arthur martin
Reference ADEPEM : 005364
Module de puissance 14012689524/6*
Type: ModulesElectrolux, Faure
Reference ADEPEM : 203679
Pied reglable 1250119029
Reference ADEPEM : 017304
Resistance 1400w/1000w 125436512/3
Type: ResistancesFaure, Arthur martin, Zanussi
Reference ADEPEM : 048012
Ressort
Reference ADEPEM : 054972
Turbine arriere
Type: Ventilateurs et helicesElectrolux, Faure, Zanussi
Reference ADEPEM : 134088
Turbine ventilation moteur
Type: Ventilateurs et helicesZanussi, Electrolux, Faure
Reference ADEPEM : 041197
Ventilateur four 18-22w 71x3193
Type: Ventilateurs et helicesBrandt, De dietrich, Sauter
Reference ADEPEM : 059617
Courroie 1971h7, 140056254018
Reference ADEPEM : 144216
Palier seche-linge
Reference ADEPEM : 005245
Resistance 1630w+750w 5009793800/0
Type: ResistancesFaure, Arthur martin, Lincoln
Reference ADEPEM : 030757
Sonde de temperature 3792171021
Type: Capteurs et sondesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 051617
Filtre a peluches, 8074539019
Type: FiltresElectrolux, Faure, A.e.g
Reference ADEPEM : 193120
Cable d'alimentation+antiparasite 0,27µf
Type: Cables et cordonsZanussi, Electrolux, Faure
Reference ADEPEM : 155893
Condensateur 6µf 400v 1125429009
Type: CondensateursElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 075173
Feutre avant 125836800/8
Type: DiversFaure, Zanussi, Arthur martin
Reference ADEPEM : 017853
Thermostat sonde 8074873012
Type: ThermostatsElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 069868
Antiparasite 0,47µf + cordon
Reference ADEPEM : 124795
Axe de tambour seche-linge
Type: Cuves et tamboursFaure, Electrolux, Arthur martin
Reference ADEPEM : 005250
Bouchon de sortie d'air
Type: BouchonsZanussi, Faure, Arthur martin
Reference ADEPEM : 055196
Charbon 6x6x19 (par 1)
Type: Charbons moteurA.e.g, Electrolux, Faure
Reference ADEPEM : 051080
Doigt de verrou
Type: Securites et verrousElectrolux, A.e.g, Faure
Reference ADEPEM : 188040
Feutre avant
Type: DiversElectrolux, Zanussi, Faure
Reference ADEPEM : 051079
Filtre tamis seche linge
Reference ADEPEM : 062855
Palier gauche/droit
Type: Roulements et paliersFaure, Arthur martin, Zanussi
Reference ADEPEM : 030888
Thermostat
Reference ADEPEM : 053334
Condensateur 4µf, 400v, 1256418011
Reference ADEPEM : 051443
Condenseur
Type: CondenseurElectrolux, Faure, Arthur martin
Reference ADEPEM : 056603
Etrier support moteur avant
Reference ADEPEM : 155179
Feutre avant
Reference ADEPEM : 127044
Filtre inferieur
Type: FiltresZanussi, Faure, Arthur martin
Reference ADEPEM : 084164
Filtre superieur
Reference ADEPEM : 084163
Gaine seche-linge d=100
Reference ADEPEM : 037879
Interrupteur de porte
Type: Interrupteurs et switchElectrolux, A.e.g, Faure
Reference ADEPEM : 179820
Interrupteur marche arret
Type: Interrupteurs et switchZanussi, Faure, Electrolux
Reference ADEPEM : 062998
Joint avant tambour
Reference ADEPEM : 090234
Joint de feutre arriere
Type: JointsZanussi, Faure, Electrolux
Reference ADEPEM : 077033
Joint de porte
Reference ADEPEM : 063490
Joint de tambour
Type: DiversElectrolux, Faure, A.e.g
Reference ADEPEM : 174054
Module de commande*
Type: ModulesZanussi, Faure, Proline
Reference ADEPEM : 134761
Module de puissance*
Reference ADEPEM : 189543
Moteur seche linge
Type: MoteursElectrolux, Faure
Reference ADEPEM : 184457
Poignee hublot blanche 1242060000
Type: PoigneesArthur martin, Faure, Electrolux
Reference ADEPEM : 005113
Porte interieure
Reference ADEPEM : 061594
Resistance seche-linge 1000w/1400w
Type: ResistancesElectrolux, Arthur martin, Faure
Reference ADEPEM : 104396
Resistance seche-linge 1400w+600w
Type: ResistancesArthur martin, Faure, Zanussi
Reference ADEPEM : 089047
Ressort poignee hublot
Type: Amortisseurs et ressortsArthur martin, Electrolux, Faure
Reference ADEPEM : 017334
Ressort tendeur
Reference ADEPEM : 005238
Rondelle poulie
Reference ADEPEM : 040923
Type: JointsZanussi, Arthur martin, Faure
Reference ADEPEM : 010479
Ventilateur de bandeau 20w ch80003a9
Type: Ventilateurs et helicesBrandt, Sauter, De dietrich
Reference ADEPEM : 038348
Verrou de porte
Type: Securites et verrousElectrolux, Faure, Zanussi
Reference ADEPEM : 170356
Bouchon
Type: BouchonsElectrolux, A.e.g, Zanussi
Reference ADEPEM : 089444
Couvercle tamis de porte
Reference ADEPEM : 175390
Douille support roulette
Reference ADEPEM : 105833
Feutre avant
Type: DiversArthur martin, Electrolux, Faure
Reference ADEPEM : 017328
Filtre a peluches,1254242306, 1254242207
Type: FiltresElectrolux, A.e.g, Arthur martin
Reference ADEPEM : 101490
Hublot de lampe 1123424002
Type: HublotsA.e.g, Electrolux, Zanussi
Reference ADEPEM : 142920
Joint de condenseur
Reference ADEPEM : 073680
Joint feutre
Reference ADEPEM : 038291
Joint hublot 1250295001
Type: JointsZanussi, Faure, Arthur martin
Reference ADEPEM : 043636
Moteur seche linge 20583080
Type: MoteursElectrolux, A.e.g, Zanussi
Reference ADEPEM : 118410
Reservoir eau
Type: ReservoirsElectrolux, Zanussi, Faure
Reference ADEPEM : 071858
Resistance 1400w+1000w
Reference ADEPEM : 040709
Resistance seche-linge 2x1200w
Reference ADEPEM : 030763
Ressort crochet 124013903/8
Type: Amortisseurs et ressortsArthur martin, Electrolux, Zanussi
Reference ADEPEM : 005041
Tambour
Type: Cuves et tamboursElectrolux, Faure, Zanussi
Reference ADEPEM : 177104
Ventilateur 1 vitesse c00125428
Type: Ventilateurs et helicesBrandt, Scholtes, Sauter
Reference ADEPEM : 005301
Vis moteur 1240222016
Reference ADEPEM : 212420
