Reference ADEPEM : 108321
Résistance + thermostats 481231028307
Reference ADEPEM : 013191
Reference ADEPEM : 035505
Gache de porte 481227138462
Type: Securites et verrousBauknecht, Whirlpool, Laden
Reference ADEPEM : 043476
Reference ADEPEM : 029994
Courroie 1936h6 = 6phe1936
Reference ADEPEM : 048802
Pompe vidange b13-6ab03151 481070109852
Reference ADEPEM : 141387
Reference ADEPEM : 017901
Pompe de vidange c00306876
Type: PompesBauknecht, Whirlpool, Indesit
Reference ADEPEM : 065522
Courroie 1992h7 = 7ph1992
Type: CourroiesBosch, Whirlpool, Bauknecht
Reference ADEPEM : 175008
Filtre en mousse 220x100mm 481010354757
Type: FiltresWhirlpool, Bauknecht, Ignis
Reference ADEPEM : 116428
Filtre seche-linge 481010615876
Type: FiltresWhirlpool, Bauknecht, Indesit
Reference ADEPEM : 171596
Filtre triangulaire, 481010345281
Reference ADEPEM : 141599
Sonde ctn 481228219485
Reference ADEPEM : 069141
Filtre tamis seche-linge 481248058322
Reference ADEPEM : 035864
Reference ADEPEM : 046158
Condensateur 12,5µf 400v
Reference ADEPEM : 029938
Reference ADEPEM : 029934
Courroie 1810j3 481935818131
Reference ADEPEM : 040007
Roulette de tambour, 481010456115
Type: Roues et roulettesWhirlpool, Bauknecht, Laden
Reference ADEPEM : 172506
Gache de porte 481227138354
Reference ADEPEM : 013211
Courroie 1965h8
Reference ADEPEM : 029990
Reference ADEPEM : 048857
Turbine de ventilation c00738545
Type: Ventilateurs et helicesWhirlpool, Bauknecht, Ignis
Reference ADEPEM : 128266
Reference ADEPEM : 015668
Joint de porte 481010713648
Reference ADEPEM : 111396
Reference ADEPEM : 036472
Resistance 2650w c00770287
Type: ResistancesSiltal, Bluesky, Far
Reference ADEPEM : 044837
Bouton de commande 481071425591
Type: BoutonsBauknecht, Laden, Ignis
Reference ADEPEM : 113355
Charniere de porte hublot , 481941719341
Type: CharnieresFar, Selecline, Whirlpool
Reference ADEPEM : 014698
Reference ADEPEM : 036473
Poulie tendeur 484000008521
Reference ADEPEM : 108322
Bague star turbine
Reference ADEPEM : 064493
Resistance 2400w 481010669313
Reference ADEPEM : 121831
Doigt de securite de porte 480112101518
Type: Securites et verrousWhirlpool, Laden, Bauknecht
Reference ADEPEM : 107692
Module de controle 480112101535*
Reference ADEPEM : 127543
Resistance 2500w 32x4829
Reference ADEPEM : 030791
Module de controle programmé
Type: ModulesWhirlpool, Laden, Ignis
Reference ADEPEM : 096551
Poignee hublot brune
Type: PoigneesIgnis, Laden, Radiola
Reference ADEPEM : 015551
Doigt de verrou de porte
Reference ADEPEM : 114254
Courroie 1936h8 57x0273
Type: CourroiesWhirlpool, Laden, Bauknecht
Reference ADEPEM : 019848
Courroie 1956j3 = 3pj1956
Reference ADEPEM : 030000
Reference ADEPEM : 056074
Courroie 1992h6 = 6ph1992
Type: CourroiesSiemens, Bosch, Bauknecht
Reference ADEPEM : 029989
Reference ADEPEM : 013544
Module de commande*
Reference ADEPEM : 161595
Resistance seche-linge 2x1000w
Reference ADEPEM : 091618
Joint bac a eau
Reference ADEPEM : 096023
Joint torique
Reference ADEPEM : 061202
Microswitch 3 cosses securite de pompe
Reference ADEPEM : 063798
Resistance 2050w 481225928679
Reference ADEPEM : 036803
Resistance 950w+950w 481225928928
Type: ResistancesWhirlpool, Laden, Bauknecht
Reference ADEPEM : 086120
Thermostat 147°na
Reference ADEPEM : 030939
Ecrou de turbine
Reference ADEPEM : 183280
Microswitch 2 cosses depart/securite
Reference ADEPEM : 013225
Module de commande*
Reference ADEPEM : 142202
Module de commande*
Reference ADEPEM : 165167
Poulie tendeur 481010700903
Reference ADEPEM : 143952
Touches option
Reference ADEPEM : 115898
Galet tambour
Reference ADEPEM : 038016
Bouton programmateur 481241458316
Type: BoutonsLaden, Ignis, Bauknecht
Reference ADEPEM : 086917
Pied
Reference ADEPEM : 103431
Turbine avant
Type: Ventilateurs et helicesWhirlpool, Bauknecht, Laden
Reference ADEPEM : 068621
Tuyau socle/bec verseur 480112101508
Reference ADEPEM : 147001
Joint thermostat 481932568005
Type: JointsLaden, Curtiss, Whirlpool
Reference ADEPEM : 014224
Bac recuperateur
Type: Bacs et paniersWhirlpool, Proline, Laden
Reference ADEPEM : 098487
Doigt de verrouillage 481227618422
Reference ADEPEM : 013227
Interrupteur 481227618278
Reference ADEPEM : 061566
Joint de porte 481246668607
Reference ADEPEM : 043328
Joint tambour avant 481246668561
Reference ADEPEM : 041709
Portillon condenseur c00850082
Type: PortesWhirlpool, Bauknecht, Laden
Reference ADEPEM : 192652
Sonde d'humidite filtre
Type: Capteurs et sondesBauknecht, Whirlpool, Laden
Reference ADEPEM : 054280
Antiparasite 0,1µf
Reference ADEPEM : 108455
Dectecteur de niveau d'eau
Type: Boitiers et cartersWhirlpool, Bauknecht, Laden
Reference ADEPEM : 177034
Filtre tamis 481010423761
Reference ADEPEM : 115981
Interrupteur 6 cosses 481941029126
Type: Interrupteurs et switchWhirlpool, Faure, Zanussi
Reference ADEPEM : 006199
Rondelle ressort
Reference ADEPEM : 196368
Verrou de porte
Reference ADEPEM : 195280
Adaptateur de gaine
Reference ADEPEM : 070758
Aube de tambour
Type: Aubes de tambourWhirlpool, Bauknecht, Laden
Reference ADEPEM : 075618
Axe avant + galet
Type: DiversWhirlpool, Bauknecht, Laden
Reference ADEPEM : 069890
Axe court arriere galet
Reference ADEPEM : 071127
Came de bouton
Type: BoutonsWhirlpool, Laden, Bauknecht
Reference ADEPEM : 130015
Condenseur
Type: CondenseurWhirlpool, Bauknecht, Laden
Reference ADEPEM : 114153
Condenseur
Reference ADEPEM : 064223
Interrupteur 6 cosses 92742816
Type: Interrupteurs et switchCandy, Rosieres, Faure
Reference ADEPEM : 026255
Joint de feutre arriere 480112101497
Reference ADEPEM : 143807
Joint de feutre avant 480112101685
Reference ADEPEM : 155734
Joint de filtre
Reference ADEPEM : 047083
Module de puissance 481221470748*
Reference ADEPEM : 099617
Resistance 2300w
Reference ADEPEM : 082848
Sonde humidite 480112101486
Reference ADEPEM : 177033
Touche blanche marche - arret
Type: BoutonsLaden, Ignis, Whirlpool
Reference ADEPEM : 158829
Tuyau vidange 1,50m
Type: Tuyaux et duritesBauknecht, Whirlpool, Laden
Reference ADEPEM : 059025
Verrou de porte 480112101507
Reference ADEPEM : 111778
Charniere porte
Type: CharnieresWhirlpool, Laden, Bauknecht
Reference ADEPEM : 174051
Module d'humidite 481223958063
Reference ADEPEM : 105043
Reservoir d'eau
Type: ReservoirsIgnis, Laden
Reference ADEPEM : 065718
Resistance 1900w 481231018585
Reference ADEPEM : 047442
Resistance 2700w 481010573611
Reference ADEPEM : 162306
Sonde de temperature
Reference ADEPEM : 105254
Tambour
Type: Cuves et tamboursWhirlpool, Bauknecht, Laden
Reference ADEPEM : 036471
Thermostat 120°nc/614 481928248113
Type: ThermostatsWhirlpool, Bauknecht, Laden
Reference ADEPEM : 014122
