Reference ADEPEM : 035505
Reference ADEPEM : 029992
Courroie 278h, 57x0381
Type: CourroiesBrandt, Thomson, Vedette
Reference ADEPEM : 019856
Roulement 6000z, 10x26x8mm
Reference ADEPEM : 008806
Poulie + courroie 1965h, 57x2507
Type: Pignons et pouliesBrandt, Thomson, Vedette
Reference ADEPEM : 019875
Reference ADEPEM : 029934
Courroie 1965h8
Reference ADEPEM : 029990
Filtre tamis seche-linge (tamis seul)
Type: FiltresBrandt, Thomson, Vedette
Reference ADEPEM : 019878
Microswitch 3 cosses 16a
Reference ADEPEM : 030961
Patin de frottement 57x0599
Type: PiedsBrandt, Thomson, Vedette
Reference ADEPEM : 039738
Resistance 2500w 32x4829
Reference ADEPEM : 030791
Reference ADEPEM : 018560
Courroie 1936h8 57x0273
Type: CourroiesWhirlpool, Laden, Bauknecht
Reference ADEPEM : 019848
Courroie 1985h7
Type: CourroiesBauknecht, Francia, Ocean
Reference ADEPEM : 050597
Gaine seche-linge d=90 3m
Type: Tuyaux et duritesBrandt, Vedette, Thomson
Reference ADEPEM : 019839
Resistance, 1800w+1000w, 57x2166
Reference ADEPEM : 036341
Courroie 1940h8
Type: CourroiesOcean, Vedette, Nogamatic
Reference ADEPEM : 030001
Thermostat 147°na
Reference ADEPEM : 030939
Detecteur de bac+switch
Type: Capteurs et sondesBrandt, Thomson, Vedette
Reference ADEPEM : 040206
Courroie 285h4
Type: CourroiesBrandt, Thomson, Beko
Reference ADEPEM : 134435
Joint de poulie
Type: JointsVedette, Ocean, Nogamatic
Reference ADEPEM : 019864
Antiparasite 0,1µf 2x0,15µf
Type: CondensateursBrandt, Sauter, Thermor
Reference ADEPEM : 070316
Joint arriere condenseur
Type: JointsBrandt, Fagor, Thomson
Reference ADEPEM : 038464
Condensateur 8µf 450v
Reference ADEPEM : 113548
Courroie 1860h8
Type: CourroiesCandy, Rosieres, Zerowatt
Reference ADEPEM : 029998
Joint moteur ventilateur
Type: JointsBrandt, Thomson, Vedette
Reference ADEPEM : 042261
Thermostat secu 167,5°
Type: ThermostatsBrandt, Vedette, Thomson
Reference ADEPEM : 019851
Feutre seche-linge
Reference ADEPEM : 019854
Circlip poulie
Type: Colliers et clipsBrandt, Vedette, Fagor
Reference ADEPEM : 039742
Flasque + roulement 49028330
Type: DiversCandy, Rosieres, Nogamatic
Reference ADEPEM : 183817
Palier droit
Type: Roulements et paliersBrandt, Thomson, Vedette
Reference ADEPEM : 018686
Resistance 1000w/1800w 57x3036
Reference ADEPEM : 036773
Thermostat 077b2602l=k56l1807
Type: ThermostatsOcean, Vedette, Brandt
Reference ADEPEM : 012252
Thermostat 80°/70°nc
Type: ThermostatsBrandt, Thomson, Singer
Reference ADEPEM : 047942
Clavier 2 touches
Type: ClaviersNogamatic
Reference ADEPEM : 060417
Feutre avant 68cm
Type: DiversCurling, Far, Francia
Reference ADEPEM : 048520
Hublot seche-linge
Type: HublotsCandy, Nogamatic, Rosieres
Reference ADEPEM : 025672
Reference ADEPEM : 018552
Interrupteur 6 cosses poussoir
Type: Interrupteurs et switchCandy, Rosieres, Zerowatt
Reference ADEPEM : 025645
Joint de pompe
Reference ADEPEM : 025687
Moteur ventilateur +carter
Type: Ventilateurs et helicesBrandt, Thomson, Vedette
Reference ADEPEM : 034180
Palier demi
Type: Roulements et paliersVedette, Nogamatic, Ocean
Reference ADEPEM : 019861
Palier gauche
Reference ADEPEM : 018685
Resistances 1000w + 1200w , 51x5572
Type: ResistancesBrandt, Thomson, Vedette
Reference ADEPEM : 019840
Ressort de poignee 481949248105
Type: Amortisseurs et ressortsWhirlpool, Laden, Radiola
Reference ADEPEM : 015494
Support palier seche-linge
Type: Supports et fixationsBrandt, Thomson, Vedette
Reference ADEPEM : 019870
Thermostat 140°
Type: ThermostatsBrandt, Thomson, Vedette
Reference ADEPEM : 045078
Thermostat 160°nc
Type: ThermostatsCandy, Rosieres, Nogamatic
Reference ADEPEM : 025682
Thermostat rearmable 75°93°
Type: ThermostatsCandy, Rosieres, Hoover
Reference ADEPEM : 002416
Resistance seche-linge 950+900w
Reference ADEPEM : 025688
Thermostat 60°nc/218 481928248047
Type: ThermostatsWhirlpool, Bosch, Laden
Reference ADEPEM : 014107
Resistance seche-linge 1150w + 750w
Type: ResistancesVedette, Nogamatic, Ocean
Reference ADEPEM : 019868
Moteur ventilateur 90446188
Type: Ventilateurs et helicesCandy, Rosieres, Nogamatic
Reference ADEPEM : 002415
Turbine seche-linge
Reference ADEPEM : 025607
