Condensateur 7µf c00279233
Reference ADEPEM : 114797
Reference ADEPEM : 029994
Roulement 6000z, 10x26x8mm
Reference ADEPEM : 008806
Courroie 1930h6 = 6phe1930
Reference ADEPEM : 028368
Reference ADEPEM : 070749
Courroie 1975h5 = 5phe1975
Reference ADEPEM : 005362
Resistance 2100w + thermostats 40006991
Type: ResistancesCandy, Hoover, Iberna
Reference ADEPEM : 044960
Condensateur 7,5µf 420v-450v c00095649
Type: CondensateursCandy, Rosieres, Bellavita
Reference ADEPEM : 073041
Antiparasites 0,1µf 2x0,027µf
Reference ADEPEM : 058839
Bande palier teflon
Reference ADEPEM : 024830
Joint feutre avant carter
Type: JointsRosieres
Reference ADEPEM : 069790
Courroie 1860h8
Type: CourroiesCandy, Rosieres, Zerowatt
Reference ADEPEM : 029998
Courroie 1886h5
Type: CourroiesCandy, Zerowatt, Rosieres
Reference ADEPEM : 029995
Bouchon de gaine
Type: BouchonsCandy, Hoover, Rosieres
Reference ADEPEM : 025608
Courroie 1890h9
Type: CourroiesCandy, Rosieres, Hoover
Reference ADEPEM : 002417
Flasque + roulement 49028330
Type: DiversCandy, Rosieres, Nogamatic
Reference ADEPEM : 183817
Gaine seche-linge d=100
Reference ADEPEM : 037879
Porte de tambour
Type: Cuves et tamboursCandy, Rosieres, Otsein
Reference ADEPEM : 024846
Raccord tuyau seche-linge
Reference ADEPEM : 025610
Arbre de tambour
Type: Roulements et paliersCandy, Rosieres, Hoover
Reference ADEPEM : 024826
Aube de tambour
Type: Aubes de tambourCandy, Rosieres
Reference ADEPEM : 106044
Clavier 4 touches
Type: ClaviersRosieres, Candy, Hoover
Reference ADEPEM : 025713
Douille de porte
Type: CharnieresCandy, Rosieres, Hoover
Reference ADEPEM : 025845
Ensemble anneau avant
Type: DiversCandy, Hoover, Iberna
Reference ADEPEM : 071477
Feutre avant
Reference ADEPEM : 070265
Filtre tamis seche-linge
Type: FiltresCandy, Rosieres, Hoover
Reference ADEPEM : 038672
Galet support tambour par 2
Type: Pignons et pouliesCandy, Hoover, Rosieres
Reference ADEPEM : 077266
Hublot seche-linge
Type: HublotsCandy, Nogamatic, Rosieres
Reference ADEPEM : 025672
Interrupteur 6 cosses
Type: Interrupteurs et switchRosieres
Reference ADEPEM : 025644
Interrupteur 6 cosses na
Type: Interrupteurs et switchRosieres, Candy
Reference ADEPEM : 033533
Interrupteur 6 cosses poussoir
Type: Interrupteurs et switchCandy, Rosieres, Zerowatt
Reference ADEPEM : 025645
Joint de pompe
Reference ADEPEM : 025687
Ressort poussoir
Type: Amortisseurs et ressortsCandy, Hoover, Rosieres
Reference ADEPEM : 041686
Rondelle
Reference ADEPEM : 024828
Rondelle teflon
Reference ADEPEM : 024831
Support de filtre
Reference ADEPEM : 081035
Thermostat 160°nc
Type: ThermostatsCandy, Rosieres, Nogamatic
Reference ADEPEM : 025682
Thermostat 48° / 63°
Type: ThermostatsCandy, Zerowatt, Rosieres
Reference ADEPEM : 048760
Thermostat 63°nc
Type: ThermostatsCandy, Rosieres, Hoover
Reference ADEPEM : 040245
Thermostat de sécurité 150°nc
Type: ThermostatsCandy, Rosieres, Zerowatt
Reference ADEPEM : 025650
Thermostat rearmable 75°93°
Reference ADEPEM : 002416
Resistance seche-linge 950+900w
Reference ADEPEM : 025688
Clips de plinthe par 2
Type: Colliers et clipsCandy, Hoover, Iberna
Reference ADEPEM : 120865
Programmateur
Type: Minuteurs et programmateursRosieres
Reference ADEPEM : 092476
Moteur ventilateur 90446188
Type: Ventilateurs et helicesCandy, Rosieres, Nogamatic
Reference ADEPEM : 002415
Turbine seche-linge
Reference ADEPEM : 025607
